4 cylinder 350?
Discussion in 'The Hokey Ass Message Board' started by uncle Dave, Jan 13, 2010.
  1. Jazzie77
    Jazzie77
    Hey that's wild !! U have any. Pictures or how I can look it out ?
  2. jimmy six
    jimmy six
    Keith Dordon has a SBC2 made into a V-6 for a LSR rear engine modified roadster on You Tube NA ove 600 HP... Great and shows how he did it all..
  3. Rusty O'Toole
    Rusty O'Toole
    If you want a 200 cu in engine to make cl***, Dodge had a 198 cu in slant six. And, if you are contemplating a supercharged or turbocharged engine AMC had a 199 cu in six that was hell for strong. Barney Navarro built a 700HP version with 105 lbs boost in the mid sixties, twin turbocharged and burning alcohol, to run in the Indy 500.
    https://worldpowersystems.com/AMC/Navarro-turbo-motor/index.html
    But no doubt there are more modern engines available that will make more HP with less work.
  4. RichFox
    RichFox
    Actually the SCTA cl*** structure brakes at 120 - 183 CID. And at 183 - 260 cid. So a 200 inch engine would be kind of dumb. The 170 slant 6 has been run in the 183 cl***. People have run 7 cylinder 283 to make the 260 cl***. A 4 cylinder 350 can make the 183 cl***. And many have. Lots of parts around for a SBC. And they work well. When I wanted a 183 motor I used a 3 liter Nissan V6. Lots of them around and some are pretty racy. We had a couple records for a year or two. Then Kent Richies came out with his twin Hayabusa powered car and put us out of that record,
    XXL__ likes this.
  5. RichFox
    RichFox
    Along those lines
    jimmy six likes this.
  6. RichFox
    RichFox
    This is a 9 year old thread. By now Uncle Dave has sobered up and decided he can't do this. In fact he has not been seen on the HAMB in 3 1/2 years. But it is still fun.
    panhead_pete likes this.
  7. Jalopy Joker
    Jalopy Joker
    Ha!
    look at article in Hot Rod Deluxe September 2019 starts at page 68: Half-Fast *****er (1/2 small block Chevy powered)
  8. RichFox
    RichFox
    Is it Uncle Dave? I don't get HRD.
  9. RichFox
    RichFox
  10. Which engine did Jack use?
  11. RichFox
    RichFox
    That engine was a Nissian 300Z or Maxima engine. SOHC two valve engine. But Jack used Honda V4s inline 4s, A five valve Yamaha. Hyabusas, A weird two crank sort of V4 Yamaha. Toyota car 2 liter engine. Lots of SBC engines. One a V7. Flathead. No brand loyalty there.
    Tman likes this.
  12. cfmvw
    cfmvw
    This has been some great reading! I remember reading about an engine that Ferdinand Porche experimented with in the early 1930's when he was working on an air cooled engine for his Volkswagen concept. It was a four cylinder two stroke that ran on two cylinders, with one pair supercharging the other two. It ran strong, but was also prone to overheating.
  13. Stan Back
    Stan Back
    Ron Cohn - Bob Jucewic have 18 or more Bonneville and El Mirage Cl***ic Gas and Fuel Altered and Cl***ic Production records with their Monza. Some of which use 4-cylinders in a SBC V-8 block.
  14. foolthrottle
    foolthrottle
    Saab v4
  15. X-cpe
    X-cpe
    I know this post is 9 years old, but I have to respectfully disagree. Plugging that hole would shut off 3, 5, 2, &8. (middle 2/ left side, end 2/ right side) Every other cylinder in the firing order.
  16. oldtom69
    oldtom69
    from grandin nd
    During the gas crunch of the 1970's the highly respected technical journal-Mother Earth News-did an article on running your V-8 on 4 cylinders! The guy I worked for at the time did two of them,a 440 powered ex-police car and a 455 Buick Electra 225.Both cars were so under-powered they were scary to drive. If I remember,you only had to pull the intake to make the modification [drilling and tapping the side of the lifter bore for a set screw to hold the lifter up?]Think you also removed push rods to those lifters. The 4 pistons and rods [2 middle ones on one side-end 2 on the other]just were along for the ride. He kept the Mopar for his wife to drive[poor woman] and the Buick got sold.The Mopar was pretty trouble free,but the Buick would break starter noses about every couple months.
  17. Garpo
    Garpo
    Reading through this topic, I am surprised no one pointed out that the German and British V4 and V6 engine are quite different. Sort of look similar, but nothing interchanges.
