I need a clue! Looking for an air cleaner/velocity stack for a 4 jet. Problem is it is about 4 in in diameter and most cleaners/stacks are 5+ inch. dont want to run a stock one so need some advice Geno
air cleaners used to come with a 4" reducer/adapter ring. usually plastic. try to find one with it or make one on a lathe. jerry
With more time than wisdom, I have made donuts from 10 Ga. and brased them to the required airfilter bottom. A better way is to ask the guy at the swapmeet selling air filters if he has any of the old plastic adapters. They fit the small carb neck and adapted the larger airfilters. I also made on from a piece of plastic. Glued it to the filter bottom.
I figured I would have to make one or keep an eye open for a adapter or something thanks for the info. Geno
Ive seen alot of cool cleners from other vehicles and figured that I could just adapt it to work or something like that , but like u said more time. Thanks Geno
Here's the lid but you ain't getting this one, it's on my coupe. But you can adapt most anything to it. here's a auto zone air cleaner with my base. Or you can do some thing really cool like this. 35 or 36 Ford hubcap. Use your imagination, it will come to you.
Nice cleaner, and some good ideas, i figured i would look though the yards for some ideas. I wasnt sure on the base if adapters were neeeded or 4" were made so if you want to part with the base through me a number. Geno
48 Hemi Just didnt want to embarr*** me or insult cadlights. Ok 20. for the cleaner and send ya 5. to ship it! How that?
