4-link help
Discussion in 'The Hokey Ass Message Board' started by ftw666sgv, Feb 27, 2012.
  1. ftw666sgv
    ftw666sgv
  2. resqd37Zep
    resqd37Zep
    from Nor Cal
    From looking at the picture it looks like you'll have to weld the axel portion on and the front part looks like a bolt on set up. Make sure the lower bar is parrellel with the ground. Everything else looks pre set with the bracketry. I s guess I'd have to ask just what is it you're having a problem with?
  3. 48flthdf1
    48flthdf1
    What rearend are you going to run with this kit? Just wondering. I am trying to install a 8.8 explorer with disc brakes in my 48 F1.
  4. squirrel
    "Instructions are not included and we recommend professional installation on all suspension parts."
    In other words, if you can't figure it out, you should pay someone to do it. Nice at***ude.
    Like he said, what specifically are you having trouble with?
  5. hotroddon
    hotroddon
    That's hilarious, kinda saying, "we are selling this junk but don't really know anything about it - Good Luck" :eek:
  6. pitman
    pitman
    Go to any cruise night or show, and look at a few setups under similar ch***is.
    The item I did not see was a watts link or panhard bar (and mount brackets). This would control side-to-side motion. The four links lead forward and the front bar ends use the brackets provided, attached to the frame or a crossmember (in the case of the upper links, possibly). The axle mount plates would likely offer the lower shock absorber mounts on the rear-lower, when properly positioned.
  7. Ball and Chain
    Ball and Chain
    from Nor Cal
