Hot Rods 4 Post Failure
Discussion in 'The Hokey Ass Message Board' started by dart4forte, Jan 17, 2025.
  1. 57 Fargo
    57 Fargo
    You guys better not ever see my four post, I have a gravel floor. I’m honestly amazed sometimes that anyone manages to work on cars with all of the hazards.
  2. JD Miller
    JD Miller
  3. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    I'm over cautious - I don't have the wrong idea. I know how it works.
    I'm just over cautious / personal preference. Keep it as clean and simple as possible.
    Stand alone motions with out additional weight considerations.
    49ratfink and 05snopro440 like this.
  4. HOTRODPRIMER
    HOTRODPRIMER
    I'm with you my friend, being careless and get you hurt or dead. HRP
  5. tubman
    tubman
    My thoughts exactly. It may be 100% psychological, but it is what it is. And he is right about once you get that much weight in motion.
    05snopro440 likes this.
  6. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    You can never be too safe.....
    My Dad died on the job 40 years ago with a safety manual in his shirt pocket.
    Making sure a 200 unit apartment building had heat around Christmas time ( couldn't bear the thought of people not having heat ) vs company procedures on defective equipment and steps to refusing to operate a defective piece of equipment.
    Sadly cost him his life.
    So fellas - you can never be too safe.
    Please be safe.
  7. Not relevant to the car in the OP's first post, but we can easily roll my dad's Wildfire 4-post lift around his shop on its casters with his '64 Galaxie on the lift (not raised), and he can roll the lift around the shop with no car on it by himself (He's 69).
    -Brent- and ekimneirbo like this.
  8. downlojoe33
    downlojoe33
    In my Dad’s gas station that he built in 1959, he had a single center post air/hydraulic hoist that was used when he bought it. Over time it started to leak from the center post seal and lower itself. The solution? A single 4x4 expertly measured, and placed under the rail very near the post. Then when you’re done lubing the car or truck, give it some air to fill it back up, and you could tell by the sound of it when that happened, remove said 4x4, lower vehicle, collect the money, done. Never had a failure, never replaced the seal or 4x4, and it was still in use when he sold the station in 1982.
  9. 1971BB427
    1971BB427
    from Oregon
    Back in the 1990's there was a local guy here who had a beautiful '59 Chev wagon that was a very high end build. He showed me pictures of a failure of his 4 post lift with one post going up under driver's side rear quarter panel and sticking through the side of the quarter panel near the top!
    I don't recall what caused the failure, or if he ever found out, but he did say he had the locks in and it shouldn't have failed.
    SS327 likes this.
  10. finn
    finn
    4000 lbs on a lift with ramps at 14” from the floor doesn’t give much of a moment of inertia such as to collapse a leg.
    Remember, the ramps have to be lowered for the casters to work.
    Math is your friend.
    Driver50x and ekimneirbo like this.
  11. ct1932ford
    ct1932ford
    I have had a four post lift for 30 years in two different garages. Never bolted down , but on solid concrete floors. Never an issue but common sense should always be used. I would not put car all the way up and then jack it up on the lift. Always make sure car is centered and lift level etc.. IMG_1701.jpeg
  12. finn
    finn
    Should rephrase that to say he THOUGHT he had the locks on.
    49ratfink likes this.
  13. 05snopro440
    05snopro440
    I didn't think the lift would be fully raised. My garage floor is sloped slightly towards the door for drainage. Trying to control a lift on casters with an extra 3-4,000 lbs on it ( weight of my cars I use on the lift) is not my idea of a good time. It would be fine until as long as it didn't get away from you. That's a risk I wouldn't be willing to take. Not in my plans to try it :)
  14. KenC
    KenC
    I think 2" is the max I've seen on residential in OK. And, I've never seen a parking lot that was close to level enough for a lift to set on. And, an out of level condition can overload one corner badly. Warm asphalt will flow away from the load over time, how much depends on the mix. Anyone remember what happens to it on interstates with heavy truck traffic? Yep, little ponds that hold water in the tire tracks and cause hydroplaning .
    warbird1 likes this.
  15. finn
    finn
    Shims made from plywood can do a pretty dood job of leveling things out.
    one of my lifts has a shim to level it at the corner nearest the floor drain.
    they’re quite forgiving. Not a Swiss watch by any means.
  16. BPK65
    BPK65
    Did you notice the two sets of cross tubes and runways. A type of triple stacker? Must have been a loud crash because the runway position seems to have been at full height. Looks like similar cars? https://www.roddinaz.com/wp-content/uploads/2024/01/IMG_5237.jpg
    Feel sorry as they must have spent a lot to attend this show.
    Not sure what happened, but it does highlight the fact that car lift safety should always be considered and practiced. Not sure if it was operator error or component failure but scary, nonetheless.
  17. finn
    finn
    8’ wide and 12’ tall, to the top of the posts would certainly raise my eyebrows, especially if the base is asphalt of unknown quality. 12’ is approaching twice the lift height of a typical lift.
    The 55 Chevy didn’t look like it fell from 12’, though.
    BPK65 likes this.
  18. BJR
    BJR
    So from the picture it's a Champion lift.
    BPK65 and SS327 like this.
  19. hotrodA
    hotrodA
    Another site reported that the lift company owner also owns the cars.
    49ratfink and SS327 like this.
  20. fuzzface
    fuzzface
    Just think, looking at the picture BPK65 posted above you have 9 people standing behind it not paying attention in between the 2 lifts. the outcome could have been worse if it happened during peak show hours.
    BPK65, alanp561 and 49ratfink like this.
  21. saltflats
    saltflats
    from Missouri
    Or he just bought it.
  22. hotrodlane
    hotrodlane
    Champion is just a brand name stuck on another one of these cheaply made offshore lifts. The welds are horrible on most of them and who knows what the steel has in it. I learned my lesson years ago. If your shopping for a Auto lift make sure it is ALI certified. I personally will never trust my life or anyone I know with any of the Chinese lifts on the market. For those of you that have them and think they are great. I pray your right. But some of the fails I have seen they are not for me. If your life or someone you loves life is worth the difference in price between a lift like this or a good quailty built ALI inspected lift. Then there is nothing more for me to say to you. Just my 2 cents worth
  23. arse_sidewards
    arse_sidewards
    from Central MA
    Not to interrupt this circle jerk but ***embly error seems far more likely than any sort of real failure here.
    There's a million online pictures and testimonials about lifts staying up just fine with a broken cable or failed hydro both the fancy pants brand name stuff you guys are lusting over and the cheap import stuff that tons of people buy. They're all designed and built with both cable and hydraulic failure in mind. A lift somewhere like that is gonna be brand new or nearly new and it's not gonna have any owner performed quick fixes compromise it's design.
    ekimneirbo and tubman like this.
  24. arse_sidewards
    arse_sidewards
    from Central MA
    You must have a real nice floor in there.
  25. 1971BB427
    1971BB427
    from Oregon
    Nope. He told me he always checked to make sure the locks were in place.
  26. 05snopro440
    05snopro440
    Since you said both "ALI certified" and "ALI inspected", I wanted to clarify the distinction. ALI does not inspect every lift manufactured. They examine and test each lift model and confirm the design, do***entation, and lift itself meets ANSI/ALI standard. They overload them and look for visual deformation, and the manufacturing facility must meet quality control requirements from ALI. That's the certification process.
    It's no different from certification of some kids products, an independent agency ensures that the product meets whatever standards that apply. My daughter's playpen has such a certification printed on its base.
    Beanscoot likes this.
  27. HOTRODPRIMER
    HOTRODPRIMER
    When I was a teenager working at the Singer Plant making upright vacuum cleaners, obviously the plant made Singer Vacuums but we also made the Sears brand Kenmore, Montgomery ward, J.C.Penny, Hoover & many more, the only difference was the stickers.
    There are thousands of manufactures that make a product for other companies to sell.
    Something like this accident is not a everyday occurrence, I would think there are thousands of four post lifts out there and probably less than one percent have a failure rate.
    I hate the accident happened and someone has a damaged car. HRP
    rod1 and 05snopro440 like this.
  28. 05snopro440
    05snopro440
    The center jack that I have for my four-post is sold under many manufacturer names with the same part number, same design, etc. Seems like one company makes them, and everyone marks them up and sells them.
  29. hotrodlane
    hotrodlane
    You are correct, Alot of items made by the same manufactures are simply branded by who is selling them. But just because they are made by the same manufacture does not mean they are always the same quality. Some vendors who have items made hold the manufacture to a higher quality standard and insist that they use better componets for their brand. The finished product may look the same but the quality of the product made with the better componets will last longer and is superior to the lessor product. Example most everyone will agree that Milwaukee cordless tools are awesome! But what everyone doesn't know is the company who makes these great tools for Milwaukee is the same company that makes the lessor Hart brand walmart sells and other lessor brand cordless tools. About 10-15 years ago when the cheap lifts were only $1400 shipped to your door. My buddy ordered one. and when we were putting it up the welds on the lock plates inside the columns looked like Stevie wonder welded them. When we put the left side upper column on one of the bolt sleaves snaped off where it was welded from just us tightening it up. The cables were not even 3/8. And when we rewelded the sleeve back to the column from where it broke the steel just did not weld like normal. Meaning it was almost like welding cold cast. Bottomline is we all are grown and can make our own decisions And for me I will stick with my "Rotary 12000LB 4 post" and my "Challenger 9000LB 4 post lifts" I bought them both used and rebuilt them. Both are American companies with long standing reputations in the autolift world and both my lifts are ALI certified. And buying them used and putting in some work I have less money in them than the New offshore lifts would have cost me anyhow.
    alanp561, leon bee and ekimneirbo like this.
  30. finn
    finn
    How many failures have you ACTUALLY SEEN with your own eyes, or have you been reading the Internet version of the National Enquirer?
    arse_sidewards and K13 like this.
