4-speed Behind 331 Hemi Help
Discussion in 'The Hokey Ass Message Board' started by 100mphwheelspinner, Apr 27, 2005.
  1. MY FRIEND HAS A MODEL A ROADSTER WITH A 331 LONG BELL HOUSING IN IT. HE HAD THE ORIGINAL AUTOMATIC IN IT FOR A WHILE. HE WANTS TO PUT a 4-SPEED BEHIND IT. WE KNOW ABOUT THE ADAPTER THAT HOTHEADS SELLS. WHAT ARE HIS OPTIONS? HE CAN’T FIND ANY USED ADAPTERS AND WANTS TO SAVE SOME MONEY.
  2. Chopped50Ford
    Chopped50Ford
    Alliance Vendor
    Not to High-jack the thread...but I think this is a good opportunity....hope you dont mind....
    I got a 392; I want to do the same, unless do you think I should stay w/ the stock automatic?
    where is a good place to look for stuff like this...adapters and such.
  3. seymour
    seymour
    from PNW
    seriously.
    Caps Lock.
    turn it off.
  4. I am a machine designer at work and we run all caps as a standard on prints. I am just wanting useful car info, if I wanted to know the politicaly correct way to type then I would join a computer forum.
    By the way you probably dont want to run the stock automatic. It was sluggish and robbed alot of performance.
  5. Plowboy
    Plowboy
    I wasn't too sure that you were still alive. Are you married yet?
    We may be building a car with a 331 as well, have one located, just need to buy it. It is in a 59 dodge truck with a 3 speed ******.
  6. laverda
    laverda
    Hot Heads and Wilcap will have some options. You could try to search eBay for Speed Gems (was based in MN) adapters. I was able to find a Speed Gems adapter for a four bolt manual trans. Currently the bolt pattern is for a Packard but it also fit my Ford 4spd :eek: . My '53 331 has a PowerFlite trans attached and I had considered using it .... any experience?
    Best of luck
    papa al
  7. seymour
    seymour
    from PNW
    just bustin your chops bud. i write in all caps, but don't type in caps. ;0
    you'll probably find more extended bellhousing hemi to early ford than you would the later 4 bolt. get one of them off egay or at a swap meet and then get an early ford to 4 bolt from speedway or whoever.
