Hot Rods 4 speed muncie shifting problems
Discussion in 'The Hokey Ass Message Board' started by Eric GILROY, Jul 9, 2019.
  1. Eric GILROY
    Eric GILROY
    from GILROY CA
    Has anyone with a 4 speed m22 Muncie and hurst compe***ion shifter had problems shifting from 1st to 2nd? My ****** and shifter have less than 700 miles on them.
    The problem doesn't happen every time. But when drag racing 4 out of 6 runs it stucks in first. When it happens the shifter is stuck in 1st gear position and wont move in any direction. To fix it I have to go under car and use a wench to move the 1-2 shifter arm on trans to neutral. Then it will work again. I have tried several different things.
    Here is a list of the things I have tried.
    Recalibrating shifter linage to ****** shift arms.
    Checking for any part of linkage or ****** shift arms rubbing on trans tunnel or shifter plates rubbing on trans housing.
    Backed off shifter limit bolt stops. (builder of the trans said to do that)
    I am going to try to put a go pro cam on it and see if I can record it.
    60F250 likes this.
  2. southcross2631
    southcross2631
    you may have to pull the side cover and check the shifter detents on the side cover.
    had a similar issue on a Saginaw.
    Chucky likes this.
  3. Ericnova72
    Ericnova72
    from Michigan
    Sounds like you may be overtraveling the shift slider, which is what you are actually controlling by setting the stop bolts on the shifter.....if so, backing them off was the wrong way to go, it would just make the problem worse.
    Overtraveling can make them jam or stick.
    Setting procedure for the stop bolt is:
    -Shifter fully ***embled and all linkage connected and adjusted correctly.
    -Place shifter in 3rd gear, turn front stop bolt to just contact shift tower/mechanism, then back bolt out 1 revolution and lock the jamb nut.
    -Place shifter in 2nd gear and follow the same procedure to set the rear stop bolt.
    Reason for the 1 revolution of slack on the stop bolts is to allow for flex/clearance in the linkages and still ensuring it engages the next gear correctly.
    If you still have the problem, it is inside the box and not the shifter....shift detent linkage/side cover or slider/hub/clutch keys/fork ***embly.
    catdad49 and lothiandon1940 like this.
  4. DDDenny
    Not the problem, but make sure you use GL-4 rated gear lube.
    54BOMB likes this.
  5. Eric GILROY
    Eric GILROY
    from GILROY CA
    problem is getting worst, does some know of any other manufacture of shifters or is hurst the only game in town?
  6. mgtstumpy
    mgtstumpy
    Did you align the gate with the pin inserted, limit bolts loose and shift arms off? I put a Hurst CP in a friends OT Corvette and fine tuned the adjusters and manually engaging gears on side cover. A PITA however a hoist certainly helped. It's never given any trouble since then. Also check that the shift rods aren't fouling on under body or X-member.
    lothiandon1940 likes this.
  7. sunbeam
    sunbeam
    Not what you want to hear but I'd look at the side cover or 1-2 synchronizer.
  8. 2OLD2FAST
    2OLD2FAST
    from illinois
    Is this a new shifter ? If you have to move the side plate lever from 1st gear position to neutral position then the shifter is not engaging the 1-2 internal shifter arm / plate . If that's the case , either the shifter is extremely with or the 1-2 ,/ reverse shifter separator plate is in the wrong spot ...
  9. mitch 36
    mitch 36
    I had the same issue with the m-20/ Hurst shifter in my 36, it would hang up when shifting hard only SOMETIMES and I would sternly coax the shifter around towards reverse to get it out of first. I readjusted the stops and I'm pretty sure that solved it for me.
  10. Nailhead Jason
    Nailhead Jason
    You need to get rid of the stupid plastic bushings that the shift likage uses in the the shift arms on the trans and the shifter. Replace them with a Hurst Pit Pack part number 3327302, solid bushings, I have done this with every Hurst shifter I have used since the first one 20 years ago. The plastic get sloppy fast and causes exactly what you are talking about, even faster if you are drag racing it. This will tighten it up the way you wanted it to be in the first place. Here is a link to them at Amazon.
    https://www.amazon.com/Hurst-3327302-Steel-Bushing-Pack/dp/B000BWALCO
  11. bobss396
    bobss396
    I thought the stops were for 3rd & 4th gear only. Who built the transmission? I've heard some not-so-great things about aftermarket Muncies. I agree on the parts-pack bushings and I still have broken those. Install with hi-pressure lithium grease. My shifter I use now, bought in 1978 for a 1965 Chevy, still works great. I have had it apart to clean and grease. I set it up with a 1/4" rod, arms off the transmission and made sure the levers went on without any stress. I've had to tweak a rod now and then in a vise so it flopped on freely.
  12. Binkman
    Binkman
    I had that problem on my 5-W coupe years ago.
    Like Jason, I changed the bushings out and never had another problem.
  13. badvolvo
    badvolvo
    Sounds really familiar, I tore down the shifter, cleaned and lubed, put the solid bushings in and fixed it, for a while. Then it began to do it again. The fix for me was pretty simple, I spray wd40 on the shifter ***embly a couple times a year, even know it looks well lubricated, the wd makes it work everytime. maybe its a band aid, but I don't mind cause the shifter boots not that tight and I can spray it without removing anything. The car only gets driven a few times a year, setting does not help.
  14. MAD MIKE
    MAD MIKE
    from 94577
    I'm in agreement with the shifter stops, you can't let it over travel or you will make the problem worse.
    Shifter bushings are also ****(plastic) and the sintered bronze/metal ones are not much better they tend to shatter. You need proper hardened steel ones.
    Have you checked out any of Paul Cangialosi's videos?
    He covers just about everything on Muncie issues.
    One I learned was you really need to make sure the interlock works smoothly, if the balls or springs get hung up or don't slide smoothly this can cause a hangup when shifting, and if you try and force it you may bend other thing.
    Which then leads to a sprialing PITA hole of back tracking and having to fix the *** cart in front of the donkey, before getting everything setup correctly again.
  15. 2OLD2FAST
    2OLD2FAST
    from illinois
    First , WOW , they've really gone to thinner metal for the shifters .! Second , he never did completely dis***emble the shifter .........
  16. WOW, stuff we learned 40 years ago now comes back.....
    If you can move the shifter forward and back while in 1st gear then you need to adjust the travel bolts on the front and back of the shifter. Yes, check your detent arms, most guys will overhaul the trans and not check the spring or if the detent arms are worn....The other thing to check is the end play of the main shaft....I cannot tell you how many Muncies and Saginaw ******s I repaired AFTER someone "overhauled" them....
  17. MAD MIKE
    MAD MIKE
    from 94577
    In the above video, no.
    He does have a video where he does break down an older gummed up shifter and cleans it up.
    Paul has a bunch of videos, good stuff if you are trying to diagnose a shifting problem.
  18. lothiandon1940
    lothiandon1940
    I've watched some of his videos over the years. He knows his stuff and has been doing this for decades.
  19. 2OLD2FAST
    2OLD2FAST
    from illinois
    Old and gummed up ,now we're in my wheelhouse !!
  20. DDDenny
    Both of my brand new, newer generation Hurst Comp plus shifters have a lot of slop forward/back, I tried that trick with the stops with little effect, he is right "ya gotta love Hurst".
    They sure aren't built the way they used to be!
    Taboo56Chevy likes this.
  21. birdman1
    birdman1
  22. 2OLD2FAST
    2OLD2FAST
    from illinois
    Eric , if you're still reading , as I understand what you're saying is ; when you try to shift to 2nd the shifter stops in neutral or second position, while the trans stays in 1st . Is that the case ?
  23. Mimilan
    Mimilan
    It could be a bent shift fork on 1-2 .
    An aggressive shift will cause it to jam, whereas a gentle shift will allow it to go through.
  24. bobss396
    bobss396
    I would take the side cover off and look at the shift forks, also everything in the side cover, the detents etc. I broke the stud on one of my shift lever ***emblies, changed over to an internal-thread one, got the whole side plate ***embly from Auto Gear. This should eliminate any neutral-gate problems, which seems to be your issue.
  25. DDDenny
    After watching that video, I realize I've been living under a rock, those little shift lever conversion shims are pretty cool. The Muncie for my 67 Nova is a 1969 box with a 64-67 sidecover that has studs, I found an original shifter years ago but also have a new Hurst for the 64-67 application.
    When is the last time you saw one of these?
    bobss396 likes this.
  26. Atwater Mike
    Atwater Mike
    I have a few old Hurst Compe***ion Plus shifters, used to find 'em complete or without shift rods/levers, $5 in boxes of other parts at Turlock swap.
    ...the NEW Hursts are indeed made from thinner metal, look like 'souped-up Ansen Pos-a-shifts' with Hurst hang-ons!
  27. 2OLD2FAST
    2OLD2FAST
    from illinois
    Exactly like the one in my 65 Impala , love still got one in a box somewhere ...we hard surface welded all the wear points on mine and hand filed it until it worked smooth , shifted as well as any Hurst ..( that was in '68)...you could adjust that linkage more precisley than a Hurst also ...
  28. bobss396
    bobss396
    I took my '65 Chevy apart in 1984, put the shifter back in the OG box. I cracked it open in 2014 to use... the shift knob... gone, 1/4" adjuster rod... gone... BUT I had 2 complete shifter bodies and handles. Riddle me that...
  29. DDDenny
    Hope the OP doesn't mind a little trivia here.
    That's what most people outside the Nova world usually say.
    The Nova shifter was an animal all to itself, the main body and the levers are the same but what makes it different are the shorter rods and the handle which has specific bends in it.
    No other GM car used this handle, this in combination with the spacers and a tailhousing with the extra forward shifter bosses and speedometer cable connection on the p***enger side allowed the handle to come through the console correctly.
    They are being reproduced but originals are very hard to find.
  30. greybeard360
    greybeard360
    Is it possible that the 1-2 lever is being pulled over center when in first making the shift rod in a close to straight line with the lever?
