Projects 4" top chop 31 coupe
Discussion in 'Traditional Hot Rods' started by ilija, Mar 6, 2019.
  1. ilija
    ilija
    from sweden
    Just decided to chop my 31 coupe.
    First time working on cars.
    Tigin it.
    Havent welded for 28 years.
    4 inches.
    Might need help on this one.
    I'll try to post as i go.
    Feel free to comment/advise/whatever.. received_10155602391389599.jpeg
    Wish me good luck.
  2. ilija
    ilija
    from sweden
    Started removing interior/wood etc 20190212_230333.jpg
  3. ilija
    ilija
    from sweden
  4. ilija
    ilija
    from sweden
  5. ilija
    ilija
    from sweden
  6. brady1929
    brady1929
    Cool.
    ilija likes this.
  7. ilija
    ilija
    from sweden
    dwollam and Ron Funkhouser like this.
  8. ilija
    ilija
    from sweden
  9. ilija
    ilija
    from sweden
    mgtstumpy, dwollam, GordonC and 2 others like this.
  10. sloppy jalopies
    sloppy jalopies
    Memory says you will need to make a vertical cut either side of the rear window panel as the roof is bigger at the top...
    Split the w/s post, door and quarter metal outside the gl*** , crush the bottom, spread the top, use a straight edge to keep the gl*** channels flush...
    w/s garnish will be another challenge as you cut below the swing arm... sorry no pix...
    … go illja go !
  11. Good looking car to start with,only going to get better.
    What are your plans for the running gear?
  12. deathrowdave
    deathrowdave
    from NKy
    Great work , keep after it , you’ll have a winner
  13. mopacltd
    mopacltd
    Too much chop!
    jimmysweden likes this.
  14. e z i
    e z i
    Been there, done that...
  15. mopacltd
    mopacltd
    I chopped mine 2 1/8th inch
  16. ilija
    ilija
    from sweden
    Hi again.
    Looking for advice anybody..
    Im trying to set the top as straight as i can before tacking it together.
    But the rear top is almost1/8" wider at both sides than the bottom part ! ! T-strips and rear window don't line up...
    Do i push/brace the bottom apart to make it line up OR
    will this line up when i do vertical cuts on the "corners" ??
    Suggestions are welcome as i suspect there are surely other ways to do it!?
    Thanks
  17. big duece
    big duece
    from kansas
    Line up the T strip, cut a kerf in the "top" half near where it don't line up and give it room to align up.
  18. Roothawg
    Roothawg
    I chopped a 31 4", it was just right.
    kadillackid likes this.
  19. big duece
    big duece
    from kansas
    This is an example of an A pillar on a 32 from another thread. Split the metal near where you want to move or manipulate it. Line it up, tack, fill the voids with weld. Repeat... IMGP0331.JPG
    ilija and kidcampbell71 like this.
  20. scrap metal 48
    scrap metal 48
    Chop looks good.. Keep at it....
  21. cederholm
    cederholm
    Great looking car - looks like fun! Where in Sweden are you?
    ~ Carl
  22. cederholm
    cederholm
  23. ilija
    ilija
    from sweden
    Hi !
    Im in the Southwest. Alingsås which is close to Gothenburg
    cederholm likes this.
  24. cederholm
    cederholm
    Awesome. My grandfather was from Gothenburg and I friends there. Great city.
