4 wheel disc AND power?
Discussion in 'The Hokey Ass Message Board' started by BradM32ply, Sep 18, 2013.
  1. BradM32ply
    BradM32ply
    I have 4 wheel disc on my 32 Plymouth PB build. The front is TCI IFS with GM metric large bore calipers. The rear is a 97 Explorer axle with stock disc brake setup. Someone suggested that doing 4 wheel disc AND power brakes was overkill for this car. If I could get away with manual brakes on the car, that would give me more mounting options. Opinions and other experiences are welcome please.
    Thanks,
    Brad
  2. LOWBLAZERO1
    LOWBLAZERO1
    i don't know why you'd want manual brakes on a custom built car. seems to me the better the brakes are, the safer it is.
  3. Special Ed
    Special Ed
    I run 4-wheel discs on both of my builds, and neither has a booster. Both are heavier than your Plymouth, and both stop exceptionally well. Set up the proper brake pedal ratio, and you're in business. That's is all that you need.
  4. VoodooTwin
    VoodooTwin
    from Noo Yawk
    I had the EXACT same setup on my '55 truck. I used the TCI power booster/Corvette MC and it stopped great, not overkill at all. Not sure if my truck weighed any more than your PB, it was pretty bare boned. I'd go with power brakes.
  5. no.scar.no.story
    no.scar.no.story
    I'm a big fan of brakes. I'm putting four wheel power disks on my 55 chevy pickup. No such thing as brakes too good IMAO.
  6. Special Ed
    Special Ed
    Adding a power booster will NOT improve your brakes whatsoever. It simply gives you a different pedal "feel". With the correct pedal ratio on a manual set-up, you will still fly through the windshield on a panic stop ... Seriously :)
  7. nialkc
    nialkc
    Power brakes normally use a 4/5 to one pedal ratio. Manual brakes normally use 6/7 to one ratio. Keep in mind if your rear brakes are to big in relation to the front, your car will want to swap ends in a hard stop. best bet is to always have an adjustable preportioning valve in your rear brake line .
  8. classic gary
    classic gary
    Lots of stock 60's era corvettes had manual 4wheel disk brakes......
