Technical 4 X 2 Flathead intake manifold
Discussion in 'Traditional Hot Rods' started by ocsid, Sep 6, 2015.
  1. RichFox
    RichFox
    I had a 320 cid GMC six cylinder on which I ran 3 Holley 500cfm two barrels. In a full IR set up. I expected that the very weak signal would cause the power valves to be always open. So I plugged the power valves. No worry about them. My experience after that was that the carb is not seeing a large air flow or va***e signal, so it is not dumping much fuel. But all the air in the world is flowing in there. So I needed to jet it pretty rich. It started and ran pretty good. My only real concern was WOT operation. But it didn't dump lots of fuel and I didn't expect it to.
  2. Flatheadjohn47
    Flatheadjohn47
    from Lewes, DE
    Years ago a friend of mine "Homebuilt" a bunch of flathead tunnel Rams.The 2 he built mounted 4 individual 2 barrels sideways so each throat of the carb fed an individual port of the intake.Looks good on paper,but is untested image.jpg image.jpg
    kidcampbell71 likes this.
  3. 322century
    322century
    from Europe
    For my 304 ci ...
  4. Pappys31
    Pappys31
    My dad built his with an Edelbrock 4 stack and a blow thru McCullough supercharger IMG00183-20100620-1723.jpeg
    Sent from my SM-G960U using The H.A.M.B. mobile app
