Technical 40-41 Ford Pickup Hood Support Question
Discussion in 'The Hokey Ass Message Board' started by TomT, Nov 11, 2022.
  1. TomT
    TomT
    Still working on my wife’s 40 pickup build. As many of you know I am using all 40-41 sheet metal save for the cab which is a 42-47.
    Looking at my picture there are two holes on the cowl lip to mount the hood supports. So for those who are using/have used a later cab for a 40-41 pickup build which hole did you use? Or did you have to drill one? And if so, what is the measurement from of the top of the lip to the center of the hole?
    Thanks for any help you can give.
    TomT
  2. Doublepumper
    Doublepumper
    from OR-WA, USA
    I haven't done this and don't have any answers for you. Just wanted to let you know my '46 uses the bottom hole. Good luck!
  3. TomT
    TomT
    Hey, thanks. Just not sure when using the 40 hood …..
  4. Jim Bouchard
    Jim Bouchard
    The way I understand it it as far as 40 coupe’s and sedans go, the hood support bracket has a tab on it that uses both holes
    like at the bottom of this picture
  5. TomT
    TomT
    The 40-41 Ford pickup uses the 39 Delux hood support arms without the tab - it’s just a single hole .
    From Drake’s Catslogue
  6. Jim Bouchard
    Jim Bouchard
    Yeah, see I was unaware of that.
    Good information, thanks
  7. Nailhead Jason
    Nailhead Jason
    I think it’s the top hole. You can check by putting the hood on the hinges then pooping the hood up with a pole. The support arms will be completely extended on their stops. Put the bolt in the hood and see which one is closest. It its on the top hole and it feels like to much pressure, move it to the bottom hole and the spring will have to be stretched less to close the hood, but the full ope position will be slightly lowere. Bu like I said. I believe it’s the top hole.
  8. Doublepumper
    Doublepumper
    from OR-WA, USA
    Just a side note...the Drake catalog doesn't list it, but the hood support arms on the '42-'47 are the same as used on the '40-'41.
  9. TomT
    TomT
    The 42-47 trucks are different according to Drake ….
  10. tim troutman
    tim troutman
    I have the same thing going on looks like I have mine mocked up in the bottom hole . not sure that's right 20221111_160851[1].jpg 20221111_160927[1].jpg I was just talking about getting back to work on it. still don't have the cab bolted down solid need to finish the rear cab mounts
    pprather, Hamtown Al and 40FORDPU like this.
  11. 40FORDPU
    40FORDPU
    I'm with Tim Troutman (lower holes)..did the same thing on a '46-'47 cab I used.
  12. 1947coupe
    1947coupe
    I can send you a measurement from my stock 40 pickup from the firewall lip to the hole if you like, all stock springs and hinges.
    Bandit Billy likes this.
  13. Bandit Billy
    Bandit Billy
    Post that measurement for all us to have please. I still have to fit all of that and this will make things easier.
  14. buzz4041
    buzz4041
    from Texas
    I will look at my original 40 when I get back home today and update
  15. buzz4041
    buzz4041
    from Texas
    BEAED073-9C4D-4556-A355-70A9E2756207.jpeg 16325874-1E6E-4AEF-8A5E-016C20BD8572.jpeg 844698D7-71B2-4D45-9153-47E6FA2515BA.jpeg 4204B335-5996-4390-B67F-FEDB4E6F0002.jpeg 4204B335-5996-4390-B67F-FEDB4E6F0002.jpeg 844698D7-71B2-4D45-9153-47E6FA2515BA.jpeg 16325874-1E6E-4AEF-8A5E-016C20BD8572.jpeg BEAED073-9C4D-4556-A355-70A9E2756207.jpeg So my 40 only has 1 bolt hole. It is 5” from top of rail to centerline of bolt hole. also the fender only attaches at the bottom bolt hole out of 3 in the cowl. 4204B335-5996-4390-B67F-FEDB4E6F0002.jpeg
    Hamtown Al likes this.
  16. Bandit Billy
    Bandit Billy
    ^^^^Excellent pics @buzz4041 . I don't want to go all Capn Jack Sparrow here but would you be kind enough to tilt that camera up and show me the hood attachment points? I have never had the hood on it so I am in the dark.
  17. buzz4041
    buzz4041
    from Texas
    I hope this is what your after for hood attachment points. If not let me know and I will try my best to get what you need. ED1FBAE7-3113-478E-8A5D-C919FE8DA4CC.jpeg FE65329B-ECD0-47CA-9986-69346C1AD3DD.jpeg 1B94DA62-7980-44C4-AC58-B7FEC0044DAB.jpeg ED1FBAE7-3113-478E-8A5D-C919FE8DA4CC.jpeg FE65329B-ECD0-47CA-9986-69346C1AD3DD.jpeg
  18. Bandit Billy
    Bandit Billy
  19. buzz4041
    buzz4041
    from Texas
    47 cab.jpg I looked at my 47 cab and it has the hood hinge supports from the top hole in this cab FYI. That was from when it had a 47 hood on it.
  20. Bandit Billy
    Bandit Billy
    ^^^Nice goodies! Cool firewall too. Current project?
  21. buzz4041
    buzz4041
    from Texas
    Yes it is current. I carry this one in the back of my home away from home living quarter trailer and tinker with it in
    the evenings after work. It is a tight work area now since puting cab on the ch***is, but I keep plugging away at it. That is why I pay so much attention to your thread Bandit.
  22. Bandit Billy
    Bandit Billy
    @buzz4041
    I do believe I have trailer envy. I thought mine was nice but...:eek:
    Do you have a thread on that PU?
  23. buzz4041
    buzz4041
    from Texas
    No sir I never started one. It would be a very old one if I did. lol I spend more time in this trailer than I do at home over the last 5 years.
  24. Bandit Billy
    Bandit Billy
    And don't call me sir, I work for a living! :cool:
