Technical 40 Banjo
Discussion in 'Traditional Hot Rods' started by barrnone50, Dec 11, 2015.
  1. barrnone50
    barrnone50
    from texas
    I picked up some 40s Parts. The rear End is locked up. Everything is off the the backing plates are un bolted. You can rock the axle back and forth very slightly. Should it not run freely? Any idea before I take it apart. Thanks
  2. Andy
    Andy
    Pull the plugs in the center housing and look inside. You may find the gears rusted solid.
  3. panheadguy
    panheadguy
    from S.E. WI
    OK I'll ask......are trying to turn it at the axles or the pinion shaft?
  4. Yes, it should turn freely. It would be easier with a drum on it but it should still turn.
  5. barrnone50
    barrnone50
    from texas
    Thanks for your help Fellas Tried to turn the axle with my hand. used to the dana Rears much easier to turn.
    So I took a different act with a Persuasive Approach on the Pinion and Wa la it turned freely.I got these with other parts and was told all great! Exept for the 39 box with a little problem. Well Live and learn. Thanks George
  6. von Dyck
    von Dyck
    Welllll, Barrnone, you need to get inside one of these Banjos! Dana 44s and 60s are challenging enough (compared to 9"Ford). Its kinda like comparing a VW Beetle engine rebuild to a SBC engine rebuild! The Dana and the '32 to '48 Ford rears do the same job - its how you work on 'em that's different. Lots of stuff on the HAMB to help you through it.
  7. Be sure to hold one axle still and get a feel for the spider gears; had one that turned good; but felt like it was full of rocks when differentiating. Found broken spiders gears when parting the axle out.
  8. barrnone50
    barrnone50
    from texas
    Hey von Dyck ..Yea I need to jump in.Iam gathering parts for my two door A .. I am trying finish my f1 its is taking longer than I thought.So I"ll be checking all the banjo tech for sure. Thanks for your comments..
  9. barrnone50
    barrnone50
    from texas
    Rich B yea I got a lot to learn about these little beauties I got two 40s should be able to make a big mess!!
