'40 Chevy Pickup Questions...
Discussion in 'The Hokey Ass Message Board' started by Iron Man, Oct 22, 2010.
  1. Iron Man
    Iron Man
    I have acquired a 1940 Chevy three-quarter ton pickup and I'm looking to improve it's braking and steering. Anyone know if 1940 Chevy half-ton and three-quarter ton spindles are the same? If they are, what year Chevy car brake drums can be swapped onto a 1940 Chevy pickup spindle, improving braking and giving a five bolt pattern)? And are the 1941 to 1946 Chevy car and truck steering boxes interchangeable or will I need to find one from a pickup. My thanks.
  2. Killer
    Killer
  3. tb33anda3rd
    tb33anda3rd
    half ton and three quarter ton spindles the same.
  4. 302GMC
    302GMC
    from Idaho
    Steering boxes don't interchange. You need '49-'50 front hub/drum ***'ys to work with the '40 brakes. We usually use the better '51 up Bendix 11" truck brakes & '51-'54 p***. hub/drums.
  5. Iron Man
    Iron Man
    So I need the '41 to '46 pickup steering box and column? If the six lug wheel isn't a problem do the '51 and up pickup drums and hubs bolt on the '40 spindle also? My thanks.
  6. Iron Man
    Iron Man
    I have access to a '51 or '52 half-ton that suffered a cab fire, would the front and rear axles out of it go under the '40 (3/4 ton) without major surgery? Would the steering box out of a '47 to '55 work? I'll probably just swap the drums on the front but studying my options. Again my thanks.
  7. BOWTIE BROWN
    BOWTIE BROWN
    good luck . You got to get em to stop as fast as you get em to go.
  8. Killer
    Killer
    yes.
    did you not read the anything on the stovebolt site? The tech section answers every one of your questions...
  9. junkyardjeff
    junkyardjeff
    Untill 46? the 3/4 tons shared the same basic suspension as the 1/2 tons but a longer wheelbase and the rear springs were outside the frame where the 1/2 ton were under the frame and they both had 6 lug wheels,to get 5 lugs I think the brakes and axles from a 51 to 54 will work with some modifications for a cheap conversion. A 41-6 truck steering box will be a improvement and I do recommend it as I have one in my 37.
