Hot Rods 40 Dash in a 34 Ford
Discussion in 'The Hokey Ass Message Board' started by lakepipes, May 7, 2023.
  1. lakepipes
    lakepipes
    from australia
    Hi All,
    I'd like to put a 40 ford dash into my 34 Tudor and are looking for information or pictures of how you all have handled the windscreen winder mechanism and handle. It appears that it will come through the dash but it would do so at an angle.
    Any help or suggestions would be great or if you have pictures... even better
    Thanks.
  2. Tim
    Tim
    from KCMO
    @IronTrap has a 40 dash in his 34 3 window I believe
    lakepipes likes this.
  3. joel
    joel
    39 Ford still had a crank out windshield but the dash was flatter than a '40. It might work better.
  4. lakepipes
    lakepipes
    from australia
    I checked with Matt and he’s not running with a wind out screen. But thanks for the lead.
    Tim likes this.
  5. lakepipes
    lakepipes
    from australia
    Thanks but I’m stuck on a 40, and being in Australia 40 dashes are hard to come by, 41 ford even more so.
    Okie Pete likes this.
  6. Hot Rods Ta Hell
    Hot Rods Ta Hell
    How about adapting a small power window motor to the windshield crank mechanism? You can open the windshield with the push of a ****on and not be bothered with having to adapt the crank handle to a 40 dash.
    The aftermarket has small motors that replace crank handle mechanisms, though you could do the same with any wrecking yard motor much cheaper. This one happens to have a square drive (like the 34 winder) rather than the later 16 tooth shaft. You'd need to fab a bracket for the motor and a coupler.
    https://www.summitracing.com/parts/eli-45823#overview
    Jim Bouchard likes this.
