Hot Rods 40 dash with 32 tank?
Discussion in 'The Hokey Ass Message Board' started by yngrodder, Apr 21, 2009.
  1. yngrodder
    yngrodder
    I'm Building a new car and I have a poly 32 tank that excepts after market 5 hole sending units and I,m running a 40 dash with stock guages what sending unit do I need to get for it so the gas guage reads right?
  2. Greezy
    Greezy
    I believe I have the sender you need. the sender itself has 6 holes but I have an adapter plate to fit on the 5 hole tank. Shoot me your addy and Ill send it to you. If it doesnt work send it back or send it on to someone who can use it.
  3. your `40 ford fuel gauge needs a sender that has 73 oms empty and 10 ohms full , plus you will need a voltage drop if your using 12 volts
  4. yngrodder
    yngrodder
    Thanks Guys,Mel
