Technical 40 Door Handle
Discussion in 'Traditional Hot Rods' started by mandriano, Jan 20, 2022.
  1. mandriano
    mandriano
    I'm sure this has been discussed a dozen times, but here it goes. I have a 1940 Deluxe coupe, the drivers outer handle stays up and not centered when I open the door. I have to push it down so it looks correct, so there is a 3/4 inch or so of play in the handle. Is there a way to remedy this.
  2. LOU WELLS
    LOU WELLS
    from IDAHO
    You Need To remove The Mechanism And See Where The Wear Pattern Is And Check The Stop Point.. s-l640.jpg ..
  3. mandriano
    mandriano
    Thank you I will look at that
    LOU WELLS and lothiandon1940 like this.
  4. 19Fordy
    19Fordy
    I recall that when my 40 Ford DeLuxe door handle was drooping,
    I had to replace the (partially hidden) spring shown in the latch above.
    Vendors still have them.
    I forget if I replaced the other spring but both springs are available.
    https://www.google.com/search?q=194...rome..69i57.8552j0j4&sourceid=chrome&ie=UTF-8
    I also saw this for sale latch ad on Fordbarn. Perhaps the seller can help you.
    https://www.fordbarn.com/forum/search.php?searchid=26455108&pp=25&page=2
    Here's an OEM spring source on Fordbarn
    https://www.fordbarn.com/forum/showthread.php?t=21913&highlight=1940+door+latch
