Hot Rods 40 ford ash trays
Discussion in 'The Hokey Ass Message Board' started by rl55, Feb 28, 2018.
  1. rl55
    rl55
    from az
    Hello, Can you exchange early ash trays for the later style? The early ones don't fit worth a darn. Thanks
    .org
  2. olscrounger
    olscrounger
    early ones push in and slide up-knob at bottom-late ones tilt out-knob at top. They don't interchange/fit but usually the orig ones for the dash fit as needed with a little attention. Usually the problem is in the hinge/spring/bracket on the early ones and requires a bit of work and the little springs replaced (use springs out of ball point pens) I may have a few extra doors around here for both
  3. rl55
    rl55
    from az
    Darn, found a nice pair of the late style,thought they might fit
    Came with the brackets.
