Technical 40 ford bob drake hinge mirrors
Discussion in 'Traditional Hot Rods' started by jamesu, Mar 11, 2014.
  1. jamesu
    jamesu
    Just received a pair of hinge pin mirrors from Bob Drake. I didn't know I was going to need to drill and tap the hinge.
    Anybody have any problems with that install? I don't like the idea of drilling the hinge.
    Thanks
    James
  2. pasadenahotrod
    pasadenahotrod
    from Texas
    The purpose of the drilled and tapped hole is to secure the mirror to the hinge so it rotates with the door as it opens and closes.This is how the originals were mounted so...
  3. I like mine. Not a problem on the tapped hole. I used a bottom tap.
    Charlie
  4. 19Fordy
    19Fordy
    Door hinge mirrors were not an option from Ford in 1940. Cowl mirrors were.
    Do not mess up your door hinges by drilling into them. If you mess up your hinges you are in a world of hurt. Click on the last photo.
