Technical 40 Ford brake adjustment
Discussion in 'Traditional Hot Rods' started by zgears, Feb 21, 2014.
  1. zgears
    zgears
    I'm adjusting 40 Ford brakes on a fully restored rear. Is there a brake cam socket or tool available for the lower cam stud. It's flat 1/4. It's too easy to mangle the stud or painted backing plate.
  2. tommy
    tommy
    I use a 6" crescent wrench.
  3. Old Tin and New Tin
    Old Tin and New Tin
  4. Dreddybear
    Dreddybear
    I cut a slot in a big allen and welded it inside a bigger spare socket. Works great, took about ten minutes to make. PLus it puts the wrench out away from nice backing plates..
    32owner likes this.
  5. 19Fordy
    19Fordy
    You can use a 1/4 in. open end or make one like this out of a steel strip. Wrap some electrician's tape around the wrench to prevent marring. You could also heat and bend the wrench so it is "offset".
  6. zgears
    zgears
    I ended up using a "Ford" adjustable monkey wrench, it has a nice narrow snout and clears well.
  7. lostmind
    lostmind
    Many tool makers had Ford brake adjusting wrenches up into the 1970's
    The best were 8 point box with an offset handle.
    They usually had two sizes , one for model A and one for 32 on up
    I find them a couple times a year and list them here , they sell quick.
    You can use an 8 point socket on a 3/8 breaker bar, or 1/4" bar if it's not to tight.
  8. Rich Wright
    Rich Wright
    I use a small crescent wrench but I like this idea...
    I'm going to make one later today:):)
  9. pasadenahotrod
    pasadenahotrod
    from Texas
    I found an old offset boxend wrench, forget what size, that was heated and smacked with a hammer to find the 39-41 backing plate adjusting studs. Came in handy working on the brakes on my old T bucket.
  10. OGS41
    OGS41
    Square drive socket-swivel - 1/4 " available from British car parts suppliers like Moss, LMC,Roadster Factory etc. I believe
