'40 ford brakes question...
Discussion in 'The Hokey Ass Message Board' started by bradberry00, May 30, 2004.
  1. bradberry00
    bradberry00
    Ok, just need a quick answer to this, more than likely, dumb question.
    I am disasembling my 40 ford brakes in plans of having the backing plates chromed....I have everything off but the two top adjusting screws....
    question is, are these removeable or no....if so how....it looks like there may be some kind of e-clip holding it in?????
    Thanks.....
  2. bradberry00
    bradberry00
  3. NortonG
    NortonG
    Leave them alone.
  4. Andy
    Andy
    They are not removabe except by cutting. You would have to drill the adjuster off and reweld back onto the shaft after chroming. Good luck!
  5. bradberry00
    bradberry00
    think i could get by and just chrome the backing plates with the adjusting screws still on.....??? that inner part will be painted....
    I guess i could just chrome it and then tape off the chome and sandblast the chrome off in that area to be painted.....
  6. Chopt 34
    Chopt 34
    from Florida
    I just went through the same thing on my 40 Ford rear backing plates. I did not want to go through the effort of di***embling the adjusters, so I just left the adjusters alone. There are minor imperfections of the plating at the recessed area at the base of the spring for the adjusters, although the spring and hex head plated fine. I had planned on painting the recess anyway.
    It looks fine all ***embled.
