Hot Rods 40 ford buggy spring mounting on socal flat crossmember ideas welcome
Discussion in 'The Hokey Ass Message Board' started by marfen, Apr 12, 2024.
  1. marfen
    marfen
    from sask
    32 ford coupe. I've been running a 9 leaf Socal sourced rear 40 buggy spring with their tubular crossmember with a flat spring perch and dogbones for several years. Basically the same setup as in the attached pic. Spring is sagging out a bit now and I'm wondering if attaching/tightening the spring to the flat plate on the crossmember is contributing since the 2 dogbones clamp it with 4 1/2 bolts. I'm thinking maybe a curved mounting surface on the spring perch might be better all around. I don't even think the car will sit level if they aren't tightened equally. Thoughts and ideas are appreciated.
  2. j ripper
    j ripper
    from napa ca.
    I welded some shims up in there. I think I used a couple inches of the ends of a leaf on each side.
  3. krylon32
    krylon32
    from Nebraska
    1. Central Nebraska H.A.M.B.
    I built a lot of customer chassis with my own version of a rear cross member consisting of a 3/16th wall 1.50 square tube with a laser cut 3/8 thick spring plate recessed into the tube and the spring held on by a pair of dog bones with 4.5 X 1/2 inch bolts. I always used a spring pack from Posies with a custom main leaf I had made locally. Never had any complaints about settling. Always designed the rear spring mounts so the spring shackles were at 45 degrees when loaded. Also never used a rear panard bar.
  4. marfen
    marfen
    from sask
    Thats a good idea. I will give that a shot.
