'40 ford coupe rear window seal
Discussion in 'The Hokey Ass Message Board' started by mt shasta steve, Apr 16, 2011.
  1. mt shasta steve
    mt shasta steve
    I have the seats and package tray out of the coupe, so figured this would be the time to replace the window seal. Anybody done one? Any tips on tools or techniques? It appears to me that it should install from the inside out. Any suggestions on sealer to make it water tight? I was going to use clear silicone, any better product?
    Thanks in advance!
    Steve
  2. mt shasta steve
    mt shasta steve
    Thanks skids;
    I was thinking of the string, but didn't think of two wraps and soap. Right now the project is getting all the old silicone off. That looks like it may be the hardest part of the job. Is the windshield sealer something I can get at Auto Parts, or is a gl*** shop only type thing?
  3. 19Fordy
    19Fordy
    Use this stuff. NAPA product. Cleans up with mineral spirits. Not silicone.
  4. mt shasta steve
    mt shasta steve
    Thanks for the input guys. You're right Skids, the silicone doesn't stick to the rubber, but I've spent the last two hours scrubbing the silicone off the body. Pulled the paint up in a few places. I used 3M Adhesive Cleaner #08984, it will soften the old silicone enough to scrub it off with a rag. Took me two hours to do one side. I'll NEVER use silcone on a window. The PO used the silicone.
  5. john worden
    john worden
    from iowa
    If the gl*** fit the undamaged opening properly and the rubber is fresh sealer shouldn't be needed. I allways apply one layer of black vinyl electrical tape onto the window pinch weld all the way around the opening to provide a snag free smooth surface for the rubber to slide over into position. Leave the tape.
  6. ckunsman89
    ckunsman89
    from cocoa, FL.
    i use 14 guage wire instead of rope and use plenty of soapy water. you shouldn't need any sealers if you have a good fitting piece of gl***, and a new seal.
  7. 19Fordy
    19Fordy
    I believe white vinegar helps dissolve silicone glue.
  8. vintageglass
    vintageglass
    from CT
    After 20 years of installing gl*** in vintage cars my experience is that the only thing that works is 3M automotive bedding and glazing compound Part #51135, it stays pliable. urethanes don't stick to rubber and silicone is a BIG NO NO when installing gl***.
  9. flamedabone
    flamedabone
    ....and..remember..On your 40 rear window, the thin lip of the rubber gasket goes inside. The gasket will go either way, but if the thin side is out, it will wrinkle in the corners and look goofy.
  10. 19Fordy
    19Fordy
    Thanks for the info. I printed it out for safe keeping. JIM
  11. kroozn1
    kroozn1
    I was taught to use and I have always used the creamy old style GoJo hand cleaner as lube for rubber gl*** gaskets before pulling the gl*** in. I have tried other things as lube and always go back to GoJo. If you have some.... give it a try.
    Cleans up easy too.
  12. okiedokie
    okiedokie
    from Ok
    I did mine by myself [which means you certainly can] with liquid soap on the cord and the inside of the rubber. No sealer. I don't know if it leaks yet, but I don't believe Ford originally used any sealer. I can tell you from personal experience, DO NOT USE SILICONE. Really a pretty easy job.
  13. LOWDUG37
    LOWDUG37
    Use the Drake seals,they fit the best.
  14. 296 V8
    296 V8
    from Nor~Cal
    Iv only done two and used drakes.
    They didn’t want to lay flat to the body in the corners. Had to stick it down with contact cement.
  15. stillrunners
    stillrunners
    from dallas
  16. 39 Ford
    39 Ford
    Use quality rubber and no sealer is needed.
  17. duane1946
    duane1946
    from beloit wi
    I have a 1940 ford coupe that Im building. I want to glue the windshield in on the inside. and not use the garnish molding. not sure how to cover the sides. has anyone done this before?
  18. 19Fordy
    19Fordy
    duane1946 Oh no! Please don't do that.
    40's look best with the stock divided gl*** and rubber seal.
  19. papastoyss
    papastoyss
    I've built 2 '40 coupes & have learned that gl*** not curved exactly right is what causes the gaskets not to lay down in the corners. I now only use Drake's seals & have the gl*** cut according to the pattern he supplies w/the seals. Good results.
