40 Ford Dash In????????
Discussion in 'The Hokey Ass Message Board' started by mj40's, Dec 21, 2008.
  1. rodncustom
    rodncustom
    Another case in point...(also taken from a post above)
  2. Harrison
    Harrison
    What? You don't like the "we'll just stick this up under there" look?!?!?!?
    JH
  3. yblock292
    yblock292
    btt any more 40 dashes in 30 roadsters?
  4. mcbay
    mcbay
    One in my 31 Roadster done about 12 years ago.:D
      37.6 KB
  5. yblock292
    yblock292
    can't tell in the pix but do you use the stock Model a trim piece above it? How much did you narrow it?Looks very nice.
  6. mcbay
    mcbay
    Stock Model A rail with dash bolted in so its removable. It is not cut but the ends around the ashtrays were m***aged a little to fit and keep the ashtrays working. I was surprised that a Model A was wider than a 34 as my buddy had to section his to fit.
  7. 19Fordy
    19Fordy
    The chrome pieces above and below the ashtrays are made of cold rolled steel -not pot metal. Made them and had them chromed.
  8. 40LUV
    40LUV
    from Mid Jersey
    Here's mine.
      66.4 KB
  9. yblock292
    yblock292
  10. de-fenders
    de-fenders
  11. 40 & 61 Fords
    40 & 61 Fords
    That's my buddies 32 5w. He tells people he spent so much time looking at the dash in my 40 on road trips before he had his car done, that he just had to put a 40 dash in his car too! :)
    He did a great job making it fit. Instead of cutting it through the middle, he reshaped the ends to fit it in. The edges around the gauge holes are blended smoothly into the the surrounding metal. Also, the smaller gauges are all turned towards the driver at slightly different angles, but are visually the same from the drivers view. He put the volt gauge in a panel in the glovebox, because he said that's the gauge he worries about the least, plus he didn't want to "crowd" the guages in the dash. He has well over 100 hours in the metal work on the dash. To me, It's what makes his car a standout.
  12. mj40's
    mj40's
    Nice! I can see the hours in this one. Same reason I'm putting one in my 40 pickup.
  13. mj40's
    mj40's
    Tell us more about this process. Close-up photos would be nice.
  14. mj40's
    mj40's
    Please explain more on the speaker grill treatment.
  15. HotRodFreak
    HotRodFreak
    I think the 41 Ford dash is better looking but here is my 29 roadster with 40 dash.
  16. Royalshifter
    Royalshifter
    Moderator
    Russ you need a 40 wheel in there.
  17. mj40's
    mj40's
    Speaking of 40 Wheels, who makes the better ones?
  18. Dooley
    Dooley
    from Buffalo NY
    mine was installed in the early 60's including mis matched sw gauges.
    I need to find trim or make some for the top of the dash
  19. patina33
    patina33
    I put one in my '33 roadster and am very happy. I used the Standard insert because I had 5 to chose from.
    spikemd11 likes this.
  20. Is this Dana's 34?
  21. geoford41
    geoford41
    from Delaware
    I know this is an old thread but I modified my 40 dash to use the newer SW gages and have the tach +speedo staddle the centerline of the steering wheel. Its a brushed stainless steel insert that can be removed with 6 10-32 screws
  22. 911 steve
    911 steve
    from nebraska
    center panel is engine turned aluminum holding Vintage Air controls, cruise control switches, & seat heater switches
  23. 911 steve
    911 steve
    from nebraska
    dash insert in my 40 tudor
