Technical 40 ford drum brake
Discussion in 'The Hokey Ass Message Board' started by 32kustom, Jun 7, 2020.
  1. 32kustom
    32kustom
    from Kalamazoo
    how do you Grease the front inner wheel bearing? Or get the rear seal out out of the drum?
  2. AngleDrive
    AngleDrive
    from Florida
    With drum off thread nut back on spindle. Slide drum with bearing over nut and with downward pressure yank on drum and it will pull seal out of drum along with bearing. You might be able to salvage seal if you are careful.
    67drake, Kan Kustom and 67L36Driver like this.
  3. goldmountain
    goldmountain
    I was taught that trick years ago. Sure brings back memories.
    Sent from my SM-T350 using The H.A.M.B. mobile app
  4. Kan Kustom
    Kan Kustom
  5. 32kustom
    32kustom
    from Kalamazoo
    Got it thanks
