40 Ford Drums
Discussion in 'The Hokey Ass Message Board' started by deuceroadster2, Feb 1, 2012.
  1. deuceroadster2
    deuceroadster2
    Does anyone have a spec on the maximum useable diameter of a drum off the front of a 40 Ford?
    Thanks,
    Phil
  2. ONE PUMP CHUMP
    ONE PUMP CHUMP
    I think 12.080" is the recommended limit. I have heard of some people using them at 12.120" on lighter cars. I have some on the higher side of the range and plan to use them on my car.
  3. 19Fordy
    19Fordy
    12.060 is the maximum size. I have a 40 Ford and know that to be the max. dia. although lots of folks go to 12.090.
  4. tubman
    tubman
    We never turned drums "back in the day", mainly because we were too dumb to and couldn't afford it anyway. We figured the lining (bonded shoes are best) would wear into the hills and valleys on the drums and provide more lining area.:D I don't remember ever having a problem with any of them.
  5. 19Fordy
    19Fordy
    I wonder if they wore out any faster using that method.
  6. ONE PUMP CHUMP
    ONE PUMP CHUMP
    What can happen when you exceed the limits when turning drums? Can they fail or do you lose braking power because of them distorting from being thin? Has anyone ever had one come apart?
  7. V8 Bob
    V8 Bob
    ALL of the above. :eek: Unless the car is always trailered and never sees normal road use, it's foolish to run drums that exceed their design size, and .060" is and has been the standard max oversize on most car/lt.truck drums. If the max diameter spec cannot be seen on the drum or found anywhere, stay with .060". :)
  8. pasadenahotrod
    pasadenahotrod
    from Texas
    Drums turned over spec can easily egg-out in a panic stop (T hotrod roadster, don't ask how I know that).
    Really excessive over turning can actually allow the cylinder to shoe pin/rod to drop out thus causing failure of the cylinder and total loss of brake son an old single reservoir stock master cylinder ( 57 Chevy 2door, again, don't ask).
    This applies to almost all brake drums for p***enger cars and light pickups no matter the age.
  9. ONE PUMP CHUMP
    ONE PUMP CHUMP
    Good info, thanks guys. I'll start looking for better parts than what I have.
