`40 ford experts , headlight question
Discussion in 'The Hokey Ass Message Board' started by 36-3window, Sep 9, 2006.
  1. is there a source for a 6014 headlamp that doesn't have the alighment tabs? other than the expensive ones from Bob Drake. i'm trying to find some locally and have been to 7 different auto parts stores with no luck.
    the last time i bought some for a `40 was about 8 years ago and Napa had them then.
    can those tabs be ground off?
  2. DICK SPADARO
    DICK SPADARO
    Finding headlight bulbs without the alignment pins is very difficult. You can sand of the tips with a rotary air sander and a fine coated disc. You should use water to cool the operation to prevent cracking the lens from over heating. The cooling is important so an electric sander is not a good idea. I've nipped them off with a fine stone on a grinding wheel before but the wheel must be trued and done slowly. A little clear will hide the dull spot.
  3. thanks..i'll give it a try
  4. Crusty Nut
    Crusty Nut
    I just took mine to the bench grinder and it worked perfectly. Just go slow and don't over heat the gl***. Those little nubs were gone in no time.:)
  5. sawzall
    sawzall
    i run mine with the nubs..
    however I too have heard that they can be sanded..
    can you adjust the headlight rings?
    the vintique instructions I had said the headlight doors could be "slightly bent"
  6. Heck, I just used a pair of pliers and broke mine off. Then hit the headlight with a 9" side grinder, dry. Zinged those babies right off.
    Think I've been hangin' around with Bubba and Billy Bob too much.
