Technical 40 Ford frame swap
Discussion in 'Traditional Hot Rods' started by 47chevycoupe, Oct 5, 2013.
  1. 47chevycoupe
    47chevycoupe
    from Finland
    I know this question has been asked before could not find it. Is the sedan/coupe frame the same as a convertible on a 1940 Ford?
  2. J. A. Miller
    J. A. Miller
    from Central NY
    I believe I read once that convertible frames were made with 1guage thicker steel. The convertible frames also have extra braces in the cowl area that run from the frame rail to the x-member.
  3. saltracer219
    saltracer219
    This is true Convertible and Pickup frames are made of slightly heavier gauge material. Yes they will interchange with all the other passenger cars and light trucks.
  4. 47chevycoupe
    47chevycoupe
    from Finland
    I thought they were almost identical. I looked at this car last year but he supposedly sold the car to someone else. I think he wanted more money than what we agreed to. He parted the car out and what's left is the frame. I leave Finland in the morning and when I get home I will go pickup the frame.
  5. HOTRODPRIMER
    HOTRODPRIMER
    I was under the impression they were the same except a little reinforcing in the cowl area. HRP
  6. 40FordGuy
    40FordGuy
    The frames are the same; Convert and station wagon have a piece between the left side outer rail, and the X, under the driver side floorboard. I read that car frame is 20 ga and the pickup is 11 ga.
    If you need 40 frame measurements, I can email them.
    HAPPY RODDIN' 4TTRUK
  7. J. A. Miller
    J. A. Miller
    from Central NY
    The cowl braces are on both sides, and I think you meant the car frames are 11 guage and the truck/convertible/woody frames are 10 guage.
  8. DD COOPMAN
    DD COOPMAN
    I concur...11 gauge and 10 gauge. DD
  9. R.W.JOHNSON
    R.W.JOHNSON
    Yes, i have done this on running & rolling frames several times, no problems, & yes there are 2 small additional braces on the convertible, u shold be fine, cheers, :)
