40 Ford Front End
Discussion in 'The Hokey Ass Message Board' started by Jalopy13, Aug 17, 2009.
  1. Jalopy13
    Jalopy13
    from Dayton,Oh
    I am looking for a front end to put on my 40 ford truck, would like a 3-4" drop axle, dont care if its tubular or I-beam, also spindles,backing plates,hairpins, pretty much the whole 9 yards! Let me know if you have something or know of anything! Thanks!
  2. stay with the stock unsplit wishbones if you can . Magnum makes an axle with a 38-1/2" perch center. keep your original spindles and upgrade to f-100 brakes , or disc if you must. you will need deep dropped bolt on steering arms too
  3. Aquaroscoe
    Aquaroscoe
    What are your long term plans for the power train, steering & brakes?
  4. Jalopy13
    Jalopy13
    from Dayton,Oh
    Havent really thought much about the steering yet? But I have a disc brake setup on my 9" so I was going to just run juice brakes on the front. Im not a rich man at all so whatever I can get my hands on at a descent price!
  5. 40Standard
    40Standard
    from Indy
    what's wrong with splitting the bones?
  6. 296 V8
    296 V8
    from Nor~Cal
    Why do you guys automatically jump to splitting the wish bone?
  7. nothing wrong with spitting the bones , but why do it if you don't have to? the only reason to do it on a `40 is to make room for a late model transmission ...he didn't mention one so i ***ume he has a stock motor/******. i have used the Magnum axle in several stock type 39/40 Fords without spitting the bones and it worked great. one of them i later put a 350 chevy adapted to a `39 transmission and the bones were still unsplit
    the car in my avatar has spit bones because of the 283/th350
  8. 296 V8
    296 V8
    from Nor~Cal
    My 35 has a 5 speed with un split bone.
  9. 40Standard
    40Standard
    from Indy
    that's interesting. what did you use for a ****** mount, x drop out? thanks
  10. 296 V8
    296 V8
    from Nor~Cal
    X is cut to clear trans - wide yoke (28 to 31) on bone to clear sides of trans - ball mount on bottom of new (tube) trans mount.
  11. Limey Steve
    Limey Steve
    Alliance Vendor
    from Whittier
    John at DF Metalworks has an unsplit bone & axle etc , in Ca but available.
  12. Splitting the bones gives you room for an oil pan when you swap engines. Aslo of you do any mods like flattening the spring an unsplit wish bone smaks the ch***is and limits the amount of suspension travel.
    Some fellas say that an unslpit bone handles better, but you can't prove it by me. Perhaps on the drafting board but nothing tht you can feel in the seat of your pants.
  13. 343w
    343w
    I've used the AMC spindle bosses bolted to the face of the stock ford spindle, I got the idea from a R&C annual back in the 70's. I'll try to find it if possible. That trick lets you drop the front end about 3" and you get disc brakes as well, without splinting the wishbones. I also put a GM steering box from a 70's Nova, Chevell etc with little trouble, and the Ford pitman arm matches up!
  14. trad27
    trad27
    when I split the 40 bones on my T steering raduis went to ****. dont split unless you have to.
  15. treb11
    treb11
    Oh yes you should care. DO NOT use a tube axle with a split wishbone. a tube axle cannot twist like an I-beam and it WILL break something
