Hot Rods 40 Ford headlight switch removal
Discussion in 'The Hokey Ass Message Board' started by DONS, Aug 24, 2017.
  1. DONS
    DONS
    I'm having trouble fiquring out how to remove the H/L switch on my 40 sedan. I don't see any any ****on to push to release the shaft and I don't think the knob will pull off the shaft. I did a search but couldn't find the answer. Sure would appreciate some help.
    Thank you
  2. Budget36
    Budget36
    My '42 PU had a slot in the body,I used a small flatblade to push it up, been years, but I think that's how I did it.
  3. 40LUV
    40LUV
    from Mid Jersey
    There is a hole on the side of the switch box behind the dash. Push a small nail into the hole and turn the knob at the same time.
    Kan Kustom likes this.
  4. Kan Kustom
    Kan Kustom
    Haven't had to do this but nice to know. Thanks
  5. two couped up
    two couped up
    from pa.
    Should have a hole in the back to insert a paper clip in, then pull out the knob, must start with knob pushed all the way in.
  6. DONS
    DONS
    Thank you everybody. Once I found the small hole and pushed a pin in the shaft pulled right out.
    Don
  7. jcb50
    jcb50
    I certainly didnt have that luck!!!! After many hours it didnt come out and now the parking lights are on all the time!!!!!
    ****** frustrating!!!
