Hot Rods 40 Ford Hood hinge bolt
Discussion in 'The Hokey Ass Message Board' started by jhoward51, Jul 12, 2020.
  1. jhoward51
    jhoward51
    from Georgia
    The short hood hinge ( upper) bolt broke off. Hard to reach. Probably going to take the hood off. Any tips???
  2. john worden
    john worden
    from iowa
    Can you weld a nut to the remaining part of the bolt?
    If the hood fits well now it can be difficult to achieve a good fit again on those hoods.
    Try all options before removing the hood.
    dirty old man and lothiandon1940 like this.
  3. jhoward51
    jhoward51
    from Georgia
    I can not. Removed the hood to get the remaining piece out. Someone at some time has put a heli coil in it. Thanks for the reply. Only one I got. Anymore advice would be appreciated
  4. Automotive Stud
    Automotive Stud
    Do you have room to tap it to a larger bolt diameter?
  5. missysdad1
    missysdad1
    The '40 hood hinges are a horrible design and 'way under-built. Chances are yours are bent and worn as well as having been damaged in the process of replacing the bolt you just removed. The reproduction replacement hinges are even worse, being made of soft metal they tend to bind and then bend even when you're being careful. So, keep your eye out for a pair of new-old-stock hinges...or get ready for a lifetime of misery. Good luck!
    lothiandon1940 likes this.
