40 ford hubs & drums
Discussion in 'The Hokey Ass Message Board' started by fattrodder, Oct 7, 2008.
  1. fattrodder
    fattrodder
    can these hubs and drums be drilled to a chevy bolt pattern?my wheels are chevy and i dont want wheel adapters.
  2. Crankhole
    Crankhole
  3. Cooter beat me to it...
  4. Deuce Roadster
    Deuce Roadster
    Redrilling the pattern is a simple job for a machine shop ... but you have to be careful ... :)
    See how large the center hole is in these 1940 Ford rims ? The hubs are fairly large because of the large bearing inside the hub.
    See how much smaller the center hole is on the newer rim ?
    Just because the wheel bolt pattern is redrilled to the new pattern does not mean your rim will bolt up. After market rims ( mags ) generally have a larger center because they will have to fit a larger variety of vechicles.
  5. Roadsters.com
    Roadsters.com
    Since I have a pair of '40 Ford hubs with the studs pressed out, I put some old racing wheels on them to see how they fit. There were no clearance problems with any of them.
    All of the wheels I put on the '40 hubs were made in the 1960s: American Racing Torq-Thrust 15 by 6, American Racing Torq-Thrust "D" 15 by 6, and Halibrand magnesium 15 by 4 1/2.
    Dave
    http://www.roadsters.com/
  6. Aviator
    Aviator
    Just pulled these off my '34 Ford Coupe. I was running a '55 Chevy rear-end and needed Chevy bolt pattern up front. I have now gone to a 9'' Ford rear end and upgraded the front end.
      108.6 KB
      114.1 KB
