Projects 40 Ford ignition switch
Discussion in 'Traditional Hot Rods' started by Hot Rod Bobs40, Sep 14, 2021.
Does anyone know where I can get one
Poll closed Sep 21, 2021.
  1. Switch
    0 vote(s)
    0.0%
  2. Switch
    1 vote(s)
    100.0%
Multiple votes are allowed.
  1. Hot Rod Bobs40
    Hot Rod Bobs40
    I'm trying to use my 40 Ford original Ignition switch to switch my fuel fuel pump I'm missing the little metal can with the switch operates inside of I have I have all the parts except that no that no one seems to sell it Does anybody know where I can get one
  2. stillrunners
    stillrunners
    from dallas
    Mac's doesn't sell the unit ? Or Bob Drake or Dennis Carpenter or....
  3. olscrounger
    olscrounger
    try C&G ford parts--they are out there
    lothiandon1940 likes this.
  4. Hot Rod Bobs40
    Hot Rod Bobs40
    I have the little internal switch parts the contacts and the micarta parts I don't have the little metal can that goes up against the steering column that the switch and the in the outside contacts bolt through I can't find that part
  5. Hot Rod Bobs40
    Hot Rod Bobs40
    Just searched C&G website they have everything but that part
  6. Hot Rod Bobs40
    Hot Rod Bobs40
    I was hoping to find someone who changed their steering column and might have that part in the Box and be willing to sell it
  7. Hot Rod Bobs40
    Hot Rod Bobs40
    I have tried C & G, Bob Drake, Mac's, and Dennis carpenter, nobody has the part I'm looking for I have the little plastic pieces with the contacts, I don't have the little metal can that goes up against the steering column that those parts go in, I was hoping someone might have one in a Box somewhere and be willing to sell it
  8. Dak Rat
    Dak Rat
    from NoDak
    Ask over on the Ford Barn. Someone will send you one. Make damn sure you are using that '40 switch to activate a 40-amp relay to run your fuel pump or the br*** contacts in the switch will fail.
    stillrunners and olscrounger like this.
  9. Hot Rod Bobs40
    Hot Rod Bobs40
    The pump is activated by a relay which gives minimal draw on the switch
  10. CTram37
    CTram37
    pm me i have what you need
  11. Nailhead Jason
    Nailhead Jason
    the Early Ford Store should have what you need.
