Technical 40 ford locking decklid handle ?
Discussion in 'Traditional Hot Rods' started by ohiohotrods, Oct 29, 2024.
  1. ohiohotrods
    ohiohotrods
    picked up a nice 40 ford coupe and it appears to be a drake deck lid ***embly. problem is you have to unlock it every time to get into the trunk and lock it back when done- you cant remove the key in the unlocked position? any one know a fix for it?
  2. chevyfordman
    chevyfordman
    I don't think there is a fix for that, my 40 Ford and 48 Chevy both are like that.
    warbird1 and RAK like this.
  3. maplefrm
    maplefrm
    from Central IL
    I have had a '40 Ford for 4 months now and agree the lock is rather inconvenient.
  4. 5window
    5window
    Ford and Chevy both. It's an 80 year old design issue, not a reproduction problem.
    lilCowboy likes this.
  5. okiedokie
    okiedokie
    from Ok
    I think that there are other reproductions that do allow you to unlock it and leave it unlocked. Just don't remember whose.
  6. LOU WELLS
    LOU WELLS
    from IDAHO
    My Original 40 Coupe Handle Worked Correctly...Repop Issues Today 22519418_1913806645610274_1425417047983016289_n.jpg
    lothiandon1940 likes this.
  7. 45 years ago I went to my local locksmith with that exact issue. He told me to remove the handle and leave it with him for an hour. Cost me $5.oo and I told him that was to much but paid it anyway. The key came out after unlocking and everything worked fine. It also still locked. Wish I knew what he did.
  8.
    Tow Truck Tom and LOU WELLS like this.
  9. RodStRace
    RodStRace
    It was a choice, just like not being able to close a locked door (and have the keys inside).
    The lock wafers will keep the keys from being removed in positions.
    A locksmith can probably change this for you fairly easily.
    If you want to dive deeper, look up Deviant Ollam and TSA pelican locking latches.
    It isn't HAMB stuff so I won't link.
  10. geoford41
    geoford41
    from Delaware
    Shorten a key and unlock the handle cover the tumbler with the stock SS flipper
    warbird1 and Tow Truck Tom like this.
  11. ohiohotrods
    ohiohotrods
    do what? shorten the key? how much?
    Tow Truck Tom likes this.
  12. chevyfordman
    chevyfordman
    Every original 40 I had, the key could not be removed unless locked, it's not a repop problem I believe.
  13. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Todays money, that's near $20
    Pist-n-Broke likes this.
  14. 5window
    5window
    This isn't a problem, it's an inconvenience but surely it's worth $ 20 to correct it. Skip your Starbucks for the day. :)
  15. lilCowboy
    lilCowboy
    On My 40 merc (same handle) that is an inconvenience for sure .Im gonna check with my local locksmith to see if he can do this
  16. joel
    joel
    Try this. After unlocking the trunk and lifting the lid, turn the key to lock and remove it. When you're done in the trunk just close the lid firmly and the latch will catch and hold the deck lid closed. I've been doing it for years.
