Hot Rods 40 ford master cylinder question...
Discussion in 'The Hokey Ass Message Board' started by Dynaflash_8, Aug 12, 2013.
  1. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    I picked up a reman 40 ford master, and ran into a bit of a problem. In order to attach a brake line to it, it requires an adapter. The threads are non tapered and about an inch into the master. What fitting do I need? I'm running 1/4 inch line.
  2. 296 V8
    296 V8
    from Nor~Cal
    Don’t know the name but NAPA or a decent place will have them .
  3. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    Okay. Just went to oreillys and man what a joke!
  4. yngrodder
    yngrodder
    Ive never been able to find it at a parts store , basically you are needing a banjo bolt that goes through the t that mounts at the back of the M/C the guys at your local parts store will not have a listing for it,
    You should be able to get it at a brake and clutch shop or some place like early ford or macs.
  5. Groovybaby6
    Groovybaby6
    from Denver
    You need a fitting like this or the V shaped one and a banjo fitting goes thru it with a crush washer, then you run your lines to the fitting.
  6. Christom
    Christom
    Check out C&G or Sacramento Ford. C&G have neat little exploded drawings on their site with can be most helpful if you need to look for options too.
  7. This is the correct fitting , the banjo bolt that goes through the centre has an 1/8npt female thread in it to take the brake lamp switch.
    If you have no luck getting one , I have new ones on the shelf here ( New Zealand!) , let me know if I need to send you one .
