Projects 40 ford panel
Discussion in 'The Hokey Ass Message Board' started by flathead okie, Oct 30, 2008.
  1. flathead okie
    flathead okie
    Anyone know the wheelbase and track width for a 40 Ford 1/2 ton or 3/4 ton Panel. Not for sure which one it is. Should be the same as a pick up, I think. Also, does the 40 p***enger car front fenders, hood fit?
  2. sawzall
    sawzall
    haha.. I was looking for similar info a few weeks ago.
    40 1/2 ton should have same ch***is as car and truck..
    I have a partial copy of the 1940 dealer salesmans book here that shows wheelbase as 112 which i think is universal for 40 cars
    front fenders will be close.. I think there's a small difference.. but I BELIEVE either can be subs***uted with minor mods..
    search my old posts..
  3. chopnchaneled
    chopnchaneled
    from Buford Ga.
    wheel base on a half ton is 112" has front sheetmetal similar to a car.
    wheel base on a 3/4 ton is 122" and totaly different front sheetmetal.
    also the sedan delivery looked like a car in front and only had 1 door in the rear, the panel looked different and had 2 doors in the back.
  4. pasadenahotrod
    pasadenahotrod
    from Texas
    The 40-41 1/2 ton Panel and Pickup share the frame with the P***enger Cars. The front sheet metal is not the same but the swap has been done many times.
    The 3/4 and 1 ton Panel and Pickup have a much heavier and longer frame and have a big bolt circle and 17-20 inch wheels. These use the heavier looking front end with separate headlamps on stands on the fenders.
    See the back, pages 744-772, of the 28-48 Ford "Green Bible" for illustrations of the p***enger, commercial, and truck noses and specs about wheelbase etc.
