Technical 40 Ford parallel leaf springs
Discussion in 'Traditional Hot Rods' started by nithburg, Dec 5, 2021.
  1. AKHotrod
    AKHotrod
    from Alaska
    I waited at least this long last year for mine, got side tracked on another project, so hopefully will get it installed on my 36 this summer.
    Just.dale likes this.
  2. joel
    joel
    I've used CE on 2 40 s The first was in the early/ mid 80 s and the springs were curved backwards After some driving (maybe 6-8 months) . The car rode great and the stance was good. My current 40 has springs purchased after 2000 but before Roy p***ed. They required 1 1/2 blocks to start and now have 1 in. blocks. I may go down to 1/2 in. blocks. I machined the blocks to move the axle to center the wheels in the fenders. My point is: springs settle.
    olscrounger likes this.
  3. TheOldDude
    TheOldDude
    Hey guys! I know this is an old thread but just curious if any of you used a maverick 8" with a Chasis Engineering leaf spring kit? I'm working on rebuilding the 8" atm and am planning on getting the kit next, being that I don't weld want to make sure it'll all bolt in without a need for welding anything.
    Thanks!
    lothiandon1940 likes this.
  4. 19Fordy
    19Fordy
    Keep in mind that the offset of the Ford 8 inch rear is quite big. I think, around 2 in. Check and see.
    TheOldDude likes this.
  5. okiedokie
    okiedokie
    from Ok
    I have built three 40’s with 8” Maverick and CE leafs. Works great
    lothiandon1940 and TheOldDude like this.
  6. Crusty Chevy
    Crusty Chevy
    I have '40 with a 8" from a Granada and CE leafs, no issues at all with install. I have done two CE leaf kits one Chev, one '40 Ford and can confirm no need to weld.
  7. TheOldDude
    TheOldDude
    I've got some shoebox wheels I'm going to be using. Thanks for the heads up I ***umed they fit just fine. Might have to get some new wheels.
  8. TheOldDude
    TheOldDude
    @Crusty Chevy @okiedokie
    Thanks so much! I appreciate it! Do you guys happen to remember what you all used for wheels on the rear of those 40 ford's? What offset? I have a couple of wheels off of a shoebox I was planning on using but not sure if they'll work now.
    Thanks again!
  9. putz
    putz
    from wisc.
    i used early Mustang springs fit great no issue ........
  10. Crusty Chevy
    Crusty Chevy
    I have 15 x 5 smoothie steel wheels from I believe US Wheel (got them second hand) in the rear. I think it is a standard off-set around 2 1/2-3". They only make a 6" wheel now in that size. https://www.summitracing.com/parts/usw-510-56101 I like a regular old car sized tire, not looking to fill the space with anything wider. Though it looks like a 6 or possibly a 7 could fit. There is 4" between the leaf/frame and the inside edge of the rim and around 2" over to my skirt. Know that the wheel well gets pretty narrow at the top. 39guy has a nice trick in his 40 for Uncle Mike thread on making a bit of a mini-tub to get extra tire clearance.
  11. A friend of mine used the Maverick rear and CE springs in his 36 Tudor, sway bar mounting had tight clearance to the wheels he was using. But, did clear.
  12. TheOldDude
    TheOldDude
    @Crusty Chevy much appreciated man! That is some awesome info!
  13. TheOldDude
    TheOldDude
    @Crusty Chevy How's it going man? About to buy the kit and was curious if you had to use wedges to adjust the pinion angle? Want to make sure I get everything I need to save some shipping costs.
    Thanks!
  14. hrdtlrdr
    hrdtlrdr
    early mustang rear springs,a good shop will ask you how much arch you want.
  15. Crusty Chevy
    Crusty Chevy
    I put new saddles on my 8" rear end and set up the angle when I welded it. You will probably have to do the same as the spring saddle width of your rear end will most likely not match the distance between the leaf spring pins.
  16. TheOldDude
    TheOldDude
    Thanks man! Was hoping I didn't have to deal with adjusting the perches but I guess I was wrong!
    I appreciate it!
  17. TheOldDude
    TheOldDude
    @okiedokie
    Did you have to make any modifications to the spring pads on the maverick 8"s when you installed the CE leaf kit?
    Thanks
  18. neilswheels
    neilswheels
    from England
    And, that person would have to know what dimensions to plug in to draw them up, by the time thats all done, its probably cheaper to buy a kit, made right, that fits.
  19. Bandit Billy
    Bandit Billy
    I have a maverick rear end under my 41 pickup with CE springs. Mine is a 9" posi that I had custom built, centered the pinion, I had to mount the sway bar above the axle for more room, and I welded the perches (spring pads) on myself after loading the frame to set the pinion angle. The Maverick rear end is perfect if you plan to run reverse offset wheels.
    vtx1800 and TheOldDude like this.
  20. okiedokie
    okiedokie
    from Ok
    8” from 75 Maverick in my 40 with CE springs, did not have to move perch pads.
  21. TheOldDude
    TheOldDude
    Hell yea! Haha what I wanted to hear, thanks man. My 8" is off a 72 maverick, hopefully not much different
  22. phat rat
    phat rat
    0385 (2) (2).JPG Back in the 92 when I started building the 41 CE had a low ride spring kit and I still used lowering blocks
  23. RICH B
    RICH B
    Which spring kit is that? The CE kits I have installed always put the spring hangers and shackles under the rails and it looks like your front hangers are inboard of the rails with the shackles thru the frame.
    TheOldDude and Bandit Billy like this.
  24. Bandit Billy
    Bandit Billy
    You have an excellent eye. It's a CE kit that was improved upon by @Pist-n-Broke prior to me purchasing the frame from him. No blocks required to get a wicked low stance. That's why we call him the Wizzard.
    RICH B likes this.
  25. topher5150
    topher5150
    I have an 8" on my 47 Ford. I used the CE brackets but used Dodge pickup front springs. I'm going to take them to the spring shop and see if they can flatten them out a bit......this is with 4" blocks.
    alanp561 and TheOldDude like this.
  26. TheOldDude
    TheOldDude
    @topher5150 thanks for the insight man.
    Wow, 4" blocks on that one? Holy **** I was worried my diamondback 820R15's were gonna be a tight fit. I think I'll still need some blocks, damn.
  27. alanp561
    alanp561
    Hey, @Bandit Billy, have you got pics of the front spring hangers?
    Bandit Billy likes this.
  28. phat rat
    phat rat
    I don't remember the block size, I know it wasn't 4", I used and it has CE low ride springs 0385 (2) (1).JPG
  29. topher5150
    topher5150
    This is what it looked like before I put blocks on it.
  30. TheOldDude
    TheOldDude
    @topher5150 did you use those adjustable blocks? The wheel looks way off on that image. First one looks spot on.
