Hot Rods '40 Ford Pick-UP Hood Installation.
Discussion in 'The Hokey Ass Message Board' started by Dak Rat, Feb 1, 2024.
  1. Dak Rat
    Dak Rat
    from NoDak
    Need some advice, getting ready to install the hood on my '40 truck and can't decide if the hinges should be mounted on the cowl first and then the hood dropped down or if the hinges should be installed on the hood brace and then mounted to the cowl. I don't have the fenders installed yet. It looks like it would be a real pain to try to get the 1/4" bolts into the hood and safety wired like the factory did it. Wonder what others did.
  2. fastcar1953
    fastcar1953
  3. pprather
    pprather
  4. 34 chevy
    34 chevy
    from michigan
    When i installed the hood on my 47 pickup [same cab] i mounted the hinges to the hood first.It was a lot easier that way.
    40FORDPU likes this.
  5. Bandit Billy
    Bandit Billy
    Mount the hinges on the hood first. Use the correct hardware and wire them. Then spread the hood slightly and install one side then the other. I put rubber vacuum caps over the studs to protect the paint. Use toothed washers inside to make sure they don't move around.
  6. TomT
    TomT
    Bandit Billy is spot on ……
  7. Bandit Billy
    Bandit Billy
    I bought washers like this off ebay for my 41, they are 53 F100 stuff that @Pist-n-Broke turned me onto.
    Dak Rat and Nailhead Jason like this.
  8. Dak Rat
    Dak Rat
    from NoDak
    Thank you, that is exactly what I needed to know.
