Hot Rods 40 Ford pickup cab mounting
Discussion in 'The Hokey Ass Message Board' started by AllSteel34, Jan 7, 2023.
  1. AllSteel34
    AllSteel34
    Long before I got my 40 Ford pickup, someone replaced the factory floor with a flat floor. This is presenting me with some body fit problems. Question for you 40 pickup guys: Is your cab sitting on the frame at the front mounting holes (at the firewall)?
    The replacement wood does not extend up to the front holes, so I believe the cab should be bolted down directly to the frame at the firewall.
  2. F-head
    F-head
    My 41 pickup sits on the frame at the firewall
    But I put a piece of self adhesive ch***is webbing under the feet there probably a fat 1/8” thick
    Otherwise I used a repop stock style wood kit
  3. AllSteel34
    AllSteel34
    Thanks for the confirmation! I appreciate the help.
  4. Dak Rat
    Dak Rat
    from NoDak
    On my '40, there was a piece of rubber belting 3/16 " thick. Also, from the factory there was a spring on that cowl bolt about 1.5 inches long--for vibration. Probably not needed for our modern roads.
  5. 40Standard
    40Standard
    from Indy
    where can you get the wood kit?
  6. AllSteel34
    AllSteel34
    Mac's
    All Ford
    Most any reproduction Ford parts house
  7. 2deuces64
    2deuces64
    Mack Products
    660 263 7444 Talk to Joy
    Hamtown Al likes this.
  8. joel
    joel
    I like the more expensive kit better. I have both. There is some fitting ( sanding, filing ) required; even with a good repo floor pan. Here are some pix of what the original floor and wood blocks should look like. The floor in the pix is a one piece stamping from Midwest Early Ford in Ohio. I don't know if they are still available. They saved my project.
    Firewall mount drivers side
    wood blocks extend to under the front bed mount
    IMG_2392.jpg rear cab mount drivers side
    IMG_2393.jpg mid cab mount@ front corner of seat riser (driver side)
    IMG_2401.jpg "A" pillar mount drivers side IMG_2397.jpg firewall mount.
    This is a piece of angle I added because I didn't have the seat riser in place to stiffen the floor. Even with all the stamping "ribs" it would not support my weight. Maybe if the floor was a heavier gage .....
    IMG_2394.jpg IMG_2395.jpg IMG_2396.jpg IMG_2398.jpg IMG_2390.jpg IMG_2398.jpg IMG_2399.jpg IMG_2395.jpg IMG_2396.jpg IMG_2401.jpg
    Some extra thumbnails above of the p***. side and bottom of firewall. I hope this helps.
    treb11, Hamtown Al and Bandit Billy like this.
  9. joel
    joel
    BTW The only place the body touches the wood blocks is where the bolts are.
  10. AllSteel34
    AllSteel34
    The photos are outstanding! Thank you! They are a big help.
    Would one of you do me the favor of measuring two dimensions on your truck?
    1. I need to know the vertical dimension from the bottom of the cowl to the reveal in the running board at the back of the rear fender (the vertical gap shown in the photo below). This photo is the p***enger side.
    2. I need to know the vertical dimension from the back corner of the cab to the running board, as shown by the tape measure in the photo below.
  11. joel
    joel
    I'll see if I can get something from the bottom of my doors; my cowl and cab corners are rotted away. I'll have to install my boards also.
    2deuces64 likes this.
  12. joel
    joel
    The gap from the cab to the frame looks like you're in the ballpark.
  13. hotrodA
    hotrodA
    Chris,
    Welcome to the 40-41 pickup ward.
    Can’t help you with the dimensions on mine, as the boards are not on yet.
    But I will be taking notes.
    I have the typical short cab wood kit in mine.
    @joel
    I did like you and had to add reinforcement to the floor.. It had actually sway backed in the center.
    My theory was that the trans cover didn’t add much to the support and let it bend at the opening.
  14. 2deuces64
    2deuces64
    Also maybe a measurement from the bottom of the doors ( front corner and rear corner) to the bottom of the frame wood be useful. Thanks
  15. 40Standard
    40Standard
    from Indy
    thank you for the helpful tech
  16. Bandit Billy
    Bandit Billy
    Always happy to see another 40/41 PU build. I am unable to oblige as mine is still apart from painting.
