Hot Rods 40 Ford Power Steering
Discussion in 'The Hokey Ass Message Board' started by krylon32, Apr 3, 2026 at 8:11 PM.
  1. krylon32
    krylon32
    from Nebraska
    Dam, this getting old ain't for sissies. Due to unrecoverable health problems and losing 70+ lbs I find my 40 increasingly harder to drive at slow speeds. Currently I have a new 525 GM box with a 16 inch wheel and reasonably small narrow tires on the front. I'm thinking power steering but I'm so **** I want the job to appear factory.. I'm ***uming 605 box but maybe there's a better solution. I'm not wanting cheap just good. Suggestions?
    dana barlow likes this.
  2. BJR
    BJR
    Have you thought about a bigger steering wheel. For example, a 1950 Olds came with an 18 inch diameter steering wheel. Makes a huge difference when turning the wheel at a standstill.
  3. TCTND
    TCTND
    Electric can be completely hidden under the dash. At 82 I'm looking for some comfort as well. I opted for a converted Prius unit in my '33 for financial reasons, but there are aftermarket units out there that would be simpler to integrate.
  4. tubman
    tubman
    I fee; your pain. At 84 and with arthritis in both shoulders, I am having trouble with the steering on my '51 Ford. Luckily, I live in a rural area where I can get by with sufficient planning ahead when I drive. Power steering would be a Godsend. I have a 1967 Corvette that does have power steering as a "backup", Unforeseeably, getting in and out of it s is a problem in itself. When I restored the Corvette, I thought that a power steering similar to the one in it might be an easy way to add PS to an older car. The steering box is just a regular box with nothing to do with the power steering. The power is added by a ram attached to the drag link and controlled by a control valve on the end of the link. Of course, a pump has to be mounted on the engine to run the whole thing. I am considering seeing what it would take to add such a setup to the old Ford. The steering box works fine as it is; it just takes too much effort. Because of the 6 volt system, and electric unit is out.
  5. HEATHEN
    HEATHEN
    from SIDNEY, NY
    1955-64 Chevrolet p***enger cars used the slave cylinder setup. I knew someone who adapted it to the stock steering linkage on his '32 Chevy.
