Hot Rods 40 Ford pu block huggers ?
Discussion in 'The Hokey Ass Message Board' started by putz, Jul 26, 2026.
Tags:
  1. putz
    putz
    from wisc.
    I have a 40 Ford with SBC cast iron stock header , would like to install block huggers , there really not a lot of room ... any suggestions .
  2. lake_harley
    lake_harley
    I'm of no help but have a friend who has a 40 coupe with a SBC and it had a really screwy driver side exhaust setup What exhaust manifolds are on your truck, and is the routing somewhat attractive?
    I hope you get some great help on your question.
    Lynn
  3. putz
    putz
    from wisc.
    thank you , it has stock gm ...
  4. lake_harley
    lake_harley
    Ram's horn or??? Clearance of the steering box and column appear to be the biggest challenge.
    I've never knowingly seen a set of "tight-tuck" SBC block huggers in person, but wonder if they would work in a '40 Ford?
    Lynn
  5. big duece
    big duece
    from kansas
    A Hurst front motor mount would free up some space. What steering gear is used?
  6. woodiewagon46
    woodiewagon46
    from New York
    As lake harley points out the drivers side for most '40-'48 Fords is very tight and you need to get very creative with the routing of the exhaust. Many people use a 1967-69 Chevy pick up right hand cast iron exhaust manifold on the left side of the engine. It exits towards the front of the engine to clear the steering box. Sanderson Headers offers #CC-4 header that also exits towards the front. In both cases you need to do some fancy exhaust routing. Block huggers might put you right over the steering box.
  7. anothercarguy
    anothercarguy
    20260511_130739.jpg 20260502_151532.jpg 20260502_151329.jpg 20260420_151020.jpg There is enough variance in mounting style and location that without photos of your specific instalation, we're all just guessing.
    Here's my '38 for example...same ch***is. Early 70's truck ram horns fit perfectly. I'm pretty sure I could get a set of block huggers to fit. But, I've offset my engine 1/2" to p***enger side, have my steering box up tight to the frame rail...etc.
    LOU WELLS, putz and Nailhead Jason like this.
  8. putz
    putz
    from wisc.
    thank you , you guys are Great ~
    LOU WELLS likes this.
