Technical 40` Ford Radiator / 30` Ford Grill Shell
Discussion in 'Traditional Hot Rods' started by Richard Reed, Mar 11, 2018.
  1. Richard Reed
    Richard Reed
    from Maine
    Thinking about putting a 30` or 32` Ford grill shell on the 40` Ford radiator. Have a 59A flathead and want to match the shell to the radiator. The body is a 30` roadster. Will there be any problems I should know about? Any thoughts? Thanks.
  2. HOTRODPRIMER
    HOTRODPRIMER
    I doubt very seriously it's gonna fit,the 40 radiator is bigger. HRP
    LOU WELLS likes this.
  3. steves29
    steves29
    I used a 53 customline lower tank.
    My rad guru fabricated a top tank and a core to fit a 29 shell.
  4. Richard Reed
    Richard Reed
    from Maine
    Thanks for the info guys. Back to the drawing board.
  5. sloppy jalopies
    sloppy jalopies
    Modine #397, needs the flanges trimmed but will fit in an A shell, pre '70 Ford and sbc port layout...centered filler...
    From a 1963ish Ford 6 cylinder pick up... between $125 and $150...
    I recommend a sheet of plastic light defuser...trim to fit, glue in, looks good and protects...
    ABONES and lothiandon1940 like this.
  6. typo41
    typo41
    John ****era did the same thing, but, I understand when it got hot it melted into a mess.,
  7. adam401
    adam401
    I used a 36 Ford radiator on my old av8 coupe. Used a 32 truck grill shell. Those radiators have an indentation in the bottom of the upper tank to clear the fan. That car ran a full length model A torque tube which makes things real right in front of the engine but everything fit. Those radiators are usually like 150 bucks used in good shape. Theres pics of that car in my albums. Just a thought
