Technical 40 ford rear drums
Discussion in 'Traditional Hot Rods' started by coonpiss, Aug 10, 2014.
  1. coonpiss
    coonpiss
    from NW Indiana
    Quick question, I have a set of 40 rear drums and I need to replace several studs. Do the the studs push out one by one or can I push the whole hub away from the drum? Thanks
  2. xix32
    xix32
    The studs are swaged in, the out side is swelled out up against the drums, holding the drums tight against the hub. and also holding the studs in place. you have to grind off the heads from the inside, then the studs can be pressed out toward the outside.
  3. RICH B
    RICH B
    The studs are swaged in place. If you just press them out, the hub will usually damaged. Easiest way to fix at home, without the special tools, is to grind the head off the backside and drive the stud out from the inside. New stock style studs also require swaging to hold them in place; but they make serrated press in studs for use with the repo cast iron drums. Be aware the shank is a little longer on these so depending on your wheels, you may have to make slight mods.
  4. trucker1
    trucker1
    Get a hold of **** Spadaro, He has the perfect formula with part numbers to press in modern studs. Don't try to press them out without cutting the swedge or you will ruin them. The tool is about $100. Be careful and go slow so you won't break any teeth off. Glynn.
  5. coonpiss
    coonpiss
    from NW Indiana
    Thanks gentlemen, appreciate the help!!
  6. BillyG
    BillyG
    I've read here or Ford Barn that a 7/8" hole saw will cut the swedge so you can press the studs out.
  7. Zurekbrau
    Zurekbrau
    If you don't care about the studs or drum you can do what I did to save money buying a tool to use once. I just cut off the studs flush with the brake drum then use a grinder to grind out the swedged part of the studs. Then pop them out of the hub.
  8. seabeecmc
    seabeecmc
    [​IMG] 5/8" hole saw.Regards, Ron stud2.JPG
