Technical 40 Ford Rear Hub Removal HELP
Discussion in 'Traditional Hot Rods' started by Jmorton27, Mar 29, 2016.
  1. Jmorton27
    Jmorton27
    Please tell me if someone has a sure fire way to remove the rear hubs on a 40 rear end. I don't have the funds to find one of those old school tools to do it with. Anybody have any cheap at home tricks? Anything is appreciated.
  2. Dan Timberlake
    Dan Timberlake
    48-760
    from OH
    Do not pull the hub by the wheel studs. Maybe you can clamp a modern puller to the hub recess and use a puller from one of the auto parts stores (free rental). Make sure the brake shoes are retracted and the washer under the nut removed and the packing under the washer removed. Do use a nut at the end of the axle so the axle end does not mushroom. It sometimes takes a LOT of pressure even overnight to get them off, sometimes not so much. Check with Mac VanPelt he may rent the proper puller???
  4. jimmy six
    jimmy six
    Never tried it on a Ford but on a VW you loosened the nut one turn, put the cotter pin back in, and drove home from work and it was loose. Good luck.
  5. 28dreyer
    28dreyer
    from Minnesota
    Yes, but the VW axle is straight splined into the splined drum. It also took a 3/4 drive socket and 3 foot long breaker bar to tighten them, forget about the torque wrench, just lay on that breaker bar.
    The result of not tight nut is the axle gradually wiping the splines out of the cast iron drum.
  6. adam401
    adam401
    Put a want ad up in the cl***ifieds to see if a HAMBer in your area will stop over with a hub puller and help you out. If you were near me I'd help you out. Lots of helpful guys on here.
    gotit likes this.
  7. bct
    bct
  8. bct
    bct
    Ive heard of taking a long chain and tightening to drum with a lug nut. Then whip the chain. Never tried it myself.
  9. Mac VP
    Mac VP
    Dan Hay likes this.
  10. Jmorton27
    Jmorton27
    Thanks for all the input guys!
  11. alchemy
    alchemy
    You need to put your location on your profile page. I might be just down the block from you and could loan you the proper puller.
  12. purp47
    purp47
    Same here I've got the puller for the drums.
  13. Dan Hay
    Dan Hay
    You really should use the proper tool, I too have one and would loan it if you lived close. OR, you could loosen the nut and drive around in circles with the hub you want to remove on the inside of the circle, until you hear a pop.
    But, anything other than a good puller, messing things up further is likely.
  14. Tetanus
    Tetanus
    where are you? I have a puller also
  15. the-rodster
    the-rodster
    I've let folks borrow mine several times.
    Can't really do the job without it.
    I'm in SOKY, where u at ?
    Rich
  16. I use a crows foot. I know that you are not supposed to use the lugs but I have never had a problem using them.
    Good luck maybe one of the fellas is close enough to help you.
  17. jcmarz
    jcmarz
    from Chino, Ca
    Thank God for Chevys:D
  18. Jmorton27
    Jmorton27
    I'm in Murfreesboro TN
  19. Gene Boul
    Gene Boul
    The manufactured piece is a real beast...nice and heavy. Works like a champ. I've had mine for 10 years and don't remember the cost...
  20. Fly'n Kolors
    Fly'n Kolors
    Fire, and lots of it.
  21. trad27
    trad27
    I have a regular automotive puller that I put on the resess, a little heat and PB and patients it will go. Done some seriously locked hubs that way. If near bako would be glad to loan the puller.
  22. steel rebel
    steel rebel
    Jmorton27 likes this.
