Projects 40 Ford sedan gasser.
Discussion in 'Traditional Hot Rods' started by fordcoupeguy, Apr 21, 2024.
  1. fordcoupeguy
    fordcoupeguy
    Hey guys , I think I might build a g***er out of my 40 2dr. Its gonna be on a budget using parts that I have. I have clipped the front with a Ranger twin I beam and boxed the frame. I am using a sbc auto. Again, this is done with parts I already have . Any other 40 sedan g***ers out there? Resized_20230927_104835_9620.jpeg Resized_20230927_104911_7739.jpeg Resized_20230927_104941_1752.jpeg
  2. My friend Tony is building this with set back blown BBC for street/strip. His has been a race car since the 50’s.
  3. choptop40
    choptop40
    looks like a g***er...nice work.....40 Ford 3 door project cars are popping up everywhere for little money..
  4. neilswheels
    neilswheels
    from England
    Tow Truck Tom and Dooley like this.
  5. wheeltramp brian
    wheeltramp brian
    Don't know why you would want to clip it with a Ford Ranger front end when it already has a straight axle from the factory.
    mitch 36, swade41, SS327 and 5 others like this.
  6. I have to agree with wheeltramp brian, The Ford twin I Beam is probably the worst selection you c0uld choose for any change over. If you're going to lift the wheels at all you're headed for a ride you won't soon forget.
    swade41, SS327, slayer and 5 others like this.
  7. alchemy
    alchemy
    Yeah, that struck me too as almost the worst front suspension a guy could put into a ‘40.
    Nailhead Jason, SS327, slayer and 3 others like this.
  8. lostone
    lostone
    from kansas
    ^^^agreed^^^
    Tow Truck Tom likes this.
  9. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    I agree that the twin I-beam may not be the best. Nonetheless, here are the first two machines that came to mind.
  10. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    That is one way, to add weight
    SS327, Pist-n-Broke and seb fontana like this.
  11. SS327
    SS327
    He’ll learn the first time it pulls the wheels and he goes to set it back down and it goes every way but in a straight line!
    Pist-n-Broke likes this.
  12. You got that right. I kinda hinted at that in my post without being as specific. Figured let him have the full experience of Having your Hands full!
    SS327 likes this.
  13. DDDenny
    Along with his skivvies!
    SS327 likes this.
  14. krylon32
    krylon32
    from Nebraska
    In the world of 40 sedan drag cars the Moreland black 40 sedan sets the bar. Neglected for many years after its glory years. Rescued and restored by the Lorenzini family and the current care taker Mark Herz in Portland actually taking to the track. Great history.
  15. Jack Az
    Jack Az
    Wow! That's going to be Bad ***!
  16. Ferdyeight
    Ferdyeight
    While agreeing on the ranger front end being an odd choice, it shouldn't be as big a deal as far as being uncontrollable as is being said if done correctly. They have been used in baja and prerunners for decades... just sayin.
    Cooon likes this.
  17. I totally understand the Baja side of things. Real rough terrain, lots of 1 or more wheels off the ground and the driver needs to say on the wheel full time to react. You never know what's coming next. Twin I Beam serves the purpose well. Things are a little different on the 1320' track and lifting the front end. If you have to be on the wheel to stay between the lines, you're losing time. The way twin I Beams camber, when lifted then add in any torque twist at all you will have one front tire touching down before the other one. That program will never be exact each p*** and you will have your hands full staying between the lines while you watch the *** End of a well-built ch***is go through the traps in front of you. You can prove that making 3 lifts with a floor jack. Put the jack under the front frame rails on dead center and lift the tires off the ground. Next move the jack 2" to the right and lift both off the ground again. Now go to the left of center and do it again. What did you see happen? And, while doing that watch what your steering wheel is doing.
    P.S. If you're building a G***er that don't lift the front off the ground just stay home.
    57Fury440 and SS327 like this.
