Hot Rods 40 Ford Sedan side window removal
Discussion in 'The Hokey Ass Message Board' started by wutnxt, Oct 28, 2019.
  1. wutnxt
    wutnxt
    I need some instructions on how to remove the rear side windows on my 2 door sedan. I’ve done the door windows and 1/4 windows on my coupe but haven’t had any experience with the 2door’s. Someone put em In there so I know there’s a way to get ‘em out
  2. oldiron 440
    oldiron 440
  3. oldiron 440
    oldiron 440
    If they are roll down windows there should be a trim around the window start by removing that. Next the rear seat and quarter trim. After that you will be able to roll the gl*** down to a sweet spot that you can get at the regulator and open it up far enough to get the gl*** off it, then you should be able to pull it out the window opening.
  4. BFXJason
    BFXJason
    I found this (somewhere) and used it for a guide a few month's ago. Not exactly perfect, but I took my time and was relatively easy. You will just need to use some "finesse".
    Hope it helps.
