40 ford shocks help
Discussion in 'The Hokey Ass Message Board' started by mckim2000, Mar 5, 2010.
  1. mckim2000
    mckim2000
    I need some help with my 40 ford pickup. I took everything down to the frame, have had the flathead motor redone, installed a t-5 transmission, a 9 inch ford rearend, disc brakes in front, etc. the front end is a stock axle. I am at a loss as how to install shocks both front and rear. any help and pictures would be greatly appreciated.
  2. 40FORDPU
    40FORDPU
    Try Ch***is Engineering, 319-643-2645, they offer a bolt on front shock kit #AR-2037, comes complete with the shocks. Their rear shock kit is #AR-2038A for Ford rear ends. I have used their products, they fit and work well. www.ch***isengineeringinc.com
  3. mckim2000
    mckim2000
    Thanks will check
  4. oldrelics
    oldrelics
    from Calgary
    What style of shocks do you want to install? The original lever style or modern tube style?
  5. mckim2000
    mckim2000
    I want to install the modern tube style
  6. Here is how I mounted tube shocks on a 46 merc i'm building right now. I used F-1 shock mounts for the top.
    And the rear. For the back I would recommend mounting them lower on the frame rail. Now that the weight of the car is on the ch***is, they are just touching at the top. I actually just noticed this as I took the pictures for you haha.
  7. bct
    bct
    any of those common shock mount studs will space the shock out from the frame 1/2"...but its not traditional
  8. carkiller
    carkiller
    They made a channel style front shock mount kit. I have a pair somewhere.
  9. arnamminga
    arnamminga
