OK guys, I have done a search and couldn't find my answer. I have a 1940 steering wheel that I'm trying to pull off of the original column. What I found searching was there is supposed to be two bolt holes for a steering wheel puller, but in my case there is no bolt holes. Am I supposed to remove the ring for the horn? And underneath it there will be the two holes for the puller? Sent from my iPhone using The H.A.M.B. mobile app
A bit of a gangling attempt, If you could support the base of the wheel on something, the shaft between, then you could take a hardwood block and give the center a couple love taps with the nut installed to save the threads. Might have to stand on a milk crate to do it with someone helping hold it all square, maybe do it sideways hanging off the end of a table or saw horses. That or drill n tap some holes in the center but you'd have to be outside enough to have room. If they're crooked it'll never pull. Ok a quick edit, just though of something here. I've seen old wheels that had the cast material over the threaded holes. That's to mean the bakelite may have them covered. Take a sharp awl or such and poke around. You might find em.
To the best of my knowledge that metal retainer does not come out. I have a wheel like that without the bolt holes. To remove it I left the nut on the threads but loose and flush with top of shaft. Holding up on the wheel on the cross bars I did a hard square Smack right on the nut and mine came loose. Leaving the nut on the shaft keeps from damaging the threads. I know it sounds marginal but it works. The Wizzard
I ended up taking it into work and used the hyd press. Thanks for the help. Sent from my iPhone using The H.A.M.B. mobile app
Have a Snap-On puller I inherited from the old salvage yard I worked at....have to get a pic....it did survive the fire.
I know that it’s an old thread, but Bearing puller is what a search showed, yet no pictures. Last week I had never ever heard of a bearing puller, let alone seen one. So in case there are others wanting to see how it is done with a bearing puller, here’s a picture. Obviously taken after removal from steering column .......
Sorry for the delay....... but you look like you've help a lot of folks figuring it out......have one of those as well - think it might work better...
