'40 ford wipers
Discussion in 'The Hokey Ass Message Board' started by alphabet soup, Jan 1, 2014.
  1. When I got my '40 Ford project however many years ago. It came with some replacement parts. One was a Rock Valley Auto electric wiper kit. In a box dated 1989. Unless I am doing something wrong it really doesn't fit. Has anyone used this? What did you do to make it fit?
  2. TV
    TV
    I haven't , but if you get it to work, please let me know.--TV
  3. Will be going back to it this weekend. Will let you know.
  4. pasadenahotrod
    pasadenahotrod
    from Texas
    We sold lots of those kits over the years. I even installed one in my own 40 Std. Coupe. Just bolt in place of the vacuum motor and hook up the arms and electrics.
    Chances are it could be another application mispackaged or misnumbered.
    LOU WELLS likes this.
  5. Back to the wipers. Tried every way I could think of to make the motor fit. Just not going to do it. Pasadenahotrod do you have any pictures?
  6. pasadenahotrod
    pasadenahotrod
    from Texas
    If you couldn't hook it up it is likely a 41-48 kit mismarked as a 40. The correct one for 1940 P***enger and 40-41 pickups could easily be installed without instructions and simply hooked up to the stock wiper rods.
  7. O.K., thanks. Will have to find a plan B. Gene.
  8. okiedokie
    okiedokie
    from Ok
    Newport Engineering wipers in my 40 and my 53. Great product.
    mgtstumpy, Nitroholic and olscrounger like this.
  9. Does the Newport stuff hook to the stock arms?
  10. i.rant
    i.rant
    Yes ,Bob Drake's also use the stock arms.
    Posted using the Full Custom H.A.M.B. App
    lothiandon1940 likes this.
  11. OLDSMAN
    OLDSMAN
    Throw out that kit and buy Newport. They are a direct bolt in kit and work the way they should.
  12. push_rod
    push_rod
    I installed the Rock Valley unit in my coupe back in 1988; it installed easily, and works okay, but it only has one speed, and the wiper arm sweep adjustment only allowed me to get a full sweep on the driver's side (the p***enger side does a quarter sweep... straight up, and back down!). When I built dad's 1940 Tudor, I bought and installed the Newport Engineering unit with the optional momentary wiper switch. The Newport unit allowed for better sweep adjustment, and with the optional momentary switch, it works just like a modern wiper system.
    Best regards,
    push_rod
  13. I'll try and store this in my memory banks........good info.
  14. xhotrodder
    xhotrodder
    I'm a strong supporter of Newport Engineering's Wipers. They fit perfect and work great. Had one in both my 39 Chevy, and my 40 Ford. Both worked just like they were made for the cars.
    olscrounger likes this.
  15. Thanks guys. Will call Newport next week and see what's what. Gene.
  16. Frank Compoccio
    Frank Compoccio
    I installed electric wiper motor from Speedway and install new towers with new arms. No matter what I do I cannot get the whole mechanism to work properly. The sweep ****s the park ****s. I complained to speedway they sent me a new motor. same problem. I had to drill holes in the p*** arm just to keep it from jamming. Has anyone else had these problems? Im at my wits end.
  17. Frank Compoccio
    Frank Compoccio
    Its a 40 Ford Deluxe
  18. krylon32
    krylon32
    from Nebraska
    Buy American, Newport Wipers are the best and they back them up. Speedway and Drake are cheap Chinese knockoffs.
  19. olscrounger
    olscrounger
    Newport in at least 7-8 40's great fit and work well-no issues
    pay close attention to wiper tower mechanisms. Had a set of Drakes freeze up in the body--only a couple of years old. Now I take apart orig ones, have rechromed and re***emble-seem to work well. Baxter Ford used to redo them as well may years ago.
    I don't think there are any available repo any longer-been scarce for several years.
    i.rant, lothiandon1940 and Nitroholic like this.
  20. i.rant
    i.rant
    I once sent one of my towers to Drake needing a chain replacement and they repaired it.
    I think it was $65 at the time.
