40 Ford X member/boxing plate?
Discussion in 'The Hokey Ass Message Board' started by tudormike, Jan 26, 2010.
  1. tudormike
    tudormike
    On my 40 Ford frame the X member has rusted away at the bottom where it sits inside the outer frame rail. Could I box these areas and do away with this part of the X member? Or would I be screwing up by doing this. I am in the process of making a jig for the frame before I do anything. Thanks Mike.
  2. whatever you do do not remove the center X-member!
    post some pictures so we can see how bad your rust problem is
  3. tudormike
    tudormike
    The first picture is of the p***enger side front.
    I was also planning on taking the ch***is apart to sandblast the entire ch***is.
  4. tudormike
    tudormike
    This picture is of the p***enger side rear.
    The rest of the frame seems to be soild.
  5. treb11
    treb11
  6. you have some serious rust problems there, i suggest you look for a better frame.
  7. Capt.Mike
    Capt.Mike
    I second the motion. There are many places to buy either complete frames or just rails. I had to make up new parts for my center section. Turned out nice and is strong.
  8. tudormike
    tudormike
    Thanks for the suggestions. I think I was somewhere that sells rails for $500. The front and rear crossmembers are probably the best parts on this frame.
