40 front spring on rear question
Discussion in 'The Hokey Ass Message Board' started by craigibc, Sep 1, 2012.
  1. craigibc
    craigibc
    I want to run a 40's front spring on the rear on my model A build. I have been searching and found a few threads but seems like everyone using them with a banjo rear end. I want to put one of these springs with a old Ford 9" so I will need to make some brackets for the spring.
    Do you have any photos if you have done something similar? Does anyone make these brackets? Any advice on doing this that I should know about?
    Thanks!
    Craig
  2. AV88
    AV88
    Hi you can get these from most hotrod stores I got these from SoCal speed shop in Vegas they come in whatever I.D you need for your diff ImageUploadedByTJJ1346480471.322538.jpg
  3. OLDSMAN
    OLDSMAN
    The problem that I se with this swap is that a front spring leaves are not as wide or as long as a rear spring. All of the commercially made brackets are for the wider rear leaf springs.
  4. Just cut some off the end and use front shackles.
  5. chopt top kid
    chopt top kid
    Here's my coupe!!! 2" wide 40 front spring mounted to a '69 Bronco 9" rear axle with a Pete & Jake rear spring mounting kit with 2 1/4" wide shackles. You don't have to cut your hangers, just add a couple of flat washers the same OD as the spring bushings (one on each side to keep the spring centered) and no one will ever know. The spring mounts are located on 42 1/2" centers. I also used Pete & Jake ladder bars and rear shock kit...
  6. different axle and frame but same idea. Made my own.
  7. chopt top kid
    chopt top kid
    Here's another famous rear end... (I hope B*** won't mind me posting this???) He fabricated his spring mounts from '36 rear radius rods...Neat!!!
  8. craigibc
    craigibc
    Thanks so much that is exactly what I was looking for! you guys are the best!
  9. Canuck
    Canuck
    Only shot I have. Custom rear x-mbr and 36 radius rods under a A.
    Canuck
  10. 40FordGuy
    40FordGuy
    Speedway, So cal, and I believe, Ch***is Engineering has the brackets you need.
    Happy Roddin' 4TTRUK
  11. Fordguy321
    Fordguy321
    from Arizona
    are any of the leafs removed to soften front spring?.. or build it andremoved to adlust spring later? wouldnt that mess up how shackles will be hanging?
