Hot Rods 40 left me stranded.
Discussion in 'The Hokey Ass Message Board' started by krylon32, Oct 26, 2024.
  1. krylon32
    krylon32
    from Nebraska
    Headed for C&C at Speedway early this morning and about 20 miles from home the 40 shut off and refused to restart. Everything looks good so I'm betting on the Pertronix distributor? Only the second time in my 50+ years of driving hot rods all over the country I've had to call a rollback. Thankfully I wasn't very far from home, only about a 90 mile round trip for the rollback. Dam old cars!
  2. 19Fordy
    19Fordy
    Gary, Sorry about your Pertronix failure. Be sure and let us know what caused the failure. I also have a Pertronix in my 40 with an 8BA. Hope it all gets fixed with no additional problems.
  3. tubman
    tubman
    Just shut off? Sounds like a Pertronix. I would suggest changing the ***le of this thread if you find that's the problem.
    Old Fords themselves are pretty damn reliable. My '51 has done this to me once in the 38 years I have owned it, and that was my fault as I was testing my 12 volt tach driver and it failed and shorted the ignition. Damned electronics!
  4. bobkatrods
    bobkatrods
    from aledo tx
    Seems to be a lot of issues with the Pertronix, I know several people that have broke down on the road with them.
  5. RmK57
    RmK57
    Might be a good idea to carry a spare in the glovebox….just like a set of points and condenser in the old days.
  6. tubman
    tubman
    I think statements like this say more about Pertronix than anything else. I have never even considered the need to carry spares during normal use. I do make an exception for trips of over 1000 miles, more because of availability issues than reliability ones.
  7. olscrounger
    olscrounger
    My 40 did that --never an issue before--no spark. Found an old coil and put it in. Started right up!! Bad pertronix coil. Car had a pertronix kit in the distributor and a pertronix coil-left the old coil in it --no more problem.
  8. krylon32
    krylon32
    from Nebraska
    I'll report back with the diagnosis. When I got stopped I was about 2 feet outside the white line. I did learn one thing, there a lot of courteous drivers who move over when going by but there a few ***holes who try and see how close they can get as they come by including a couple semi's. Nerve wracking sitting along a busy 4 lane in a 40 coupe even in Nebraska. I probably should have been out of the car in the ditch but it was 35 degrees.
  9. gene-koning
    gene-koning
    Keep us posted.
    The rest of the quote is the reason I quit doing road side repairs. doesn't matter if its on a 4 lane or a 2 lane (but at least on a 2 lane they may have an excuse), too many jerks out there.
    I've seen enough just plane lousy drivers, I no longer trust any of them. I'll call AAA, then walk far enough away to be safe, and wait for them.
  10. seadog
    seadog
    And you’ll wait hours for AAA to show up, at least that’s been my recent experience. They used to be pretty good at wait times, but the last time I had to use them I waited for over two hours. At that point I tinkered with the car enough to get it barely running and limped it home. Cancelled my AAA membership the next day.
    rpm56, 19Eddy30, Paul B and 3 others like this.
  11. alchemy
    alchemy
    It can’t be the distributor. Pertronix is the answer to all that ails you.
    dogwalkin, NoSurf, RICH B and 2 others like this.
  12. HOTRODPRIMER
    HOTRODPRIMER
    I had a Pertronix die on me also, fortunately it happened in town instead of on my trip to Michigan and back, My problem was traced to using the wrong type of ignition wires but the coil wire burnt up shorting the pertronix ignition. HRP
    chryslerfan55 and Tow Truck Tom like this.
  13. jimmy six
    jimmy six
    Never had one fail but I always kept the ballast resister and cleaned the inside of the cap every 2 years.
  14. gene-koning
    gene-koning
    I have had 2 AAA tows this year and 6 or 7 over the last 8 years. The longest I've had to wait for AAA was about a 1/2 hour, that time I needed a roll back (4x4 truck). The towing operation that did the job had all his trucks out towing, he called me personally and told me the issue. But then most of my towing was within 20 miles of my home and all the operations that tow for AAA in our area all know me.
    We don't live in a very populaces area, but even then, those AAA towing companies are very busy. I don't expect them to drop everything and put me at the top of their list. Their work load and the distance the available tow truck is from the location I'm at, would make a pretty big difference on how fast they can get to me. If the truck is in the process of loading a car and is a 1/2 hour away from me, I wouldn't expect him to be there in 10 minutes, or even that 1/2 hour.
    Still not going to stand on the highway side of my ride trying to figure out what might have gone wrong, not these days.
  15. 1947coupe
    1947coupe
    I run the pertronix on my 40 pu and 47 coupe, both quit on me over the space of 18 years and it was the pertronix coil both times, last time I did have a spare.
    chryslerfan55 and olscrounger like this.
  16. krylon32
    krylon32
    from Nebraska
    Update. Super fuse was blown. Now you wonder why? When this happened I totally forgot about this fuse as it's hard to reach and remove. I do carry a spare, guess I'll know where to start if this happens again. To quick to blame the problem on Pertronix. Expensive lesson. On the subject of the coil, a friend in KC has had good success with a Bosch coil he says solved his Pertronix problems? I carry one in the pickup, may get another one for the 40 just in case.
    61Cruiser, Chavezk21, jazz1 and 8 others like this.
  17. sidevalve8ba
    sidevalve8ba
    I wonder what caused that super fuse to blow?
    okiedokie and Algoma56 like this.
  18. pprather
    pprather
    Gary, can you share the Bosch coil info, identification, source, here once again?
    Thanks.
  19. 51504bat
    51504bat
  20. V8 Bob
    V8 Bob
    You might want to check with Pertronix on what coil you need, based on your ignition, as their canisters range in primary resistance from .32 to just under 3 ohms. The Bosch blue primary is 3 ohms, and pretty sure would not work well with Flame Throwers 11 and 111, that require .6 and .32 coils.
  21. krylon32
    krylon32
    from Nebraska
    John in KC who has had a lot of Pertronix experience recommend this Bosch coil 9224 771008 12 volt high energy ignition coil. It's black not blue if that makes a difference. If I remember right this is a 3.4 ohm coil. I goggled the number and found it on line for $39.
  22. Roothawg
    Roothawg
    Not to be igniorant, but what is a "super fuse". All I get is a game, when I google it.
    Kiwi 4d and Moriarity like this.
  23. Okie Pete
    Okie Pete
    Break downs are frustrating and make for a bad day . But it also creates memories. A Friend of mine would pull out his lawn chair, grab a cold drink and start telling stories while waiting for help .
    Look at the exchange of information that your misfortune has created. Hopefully it will help others.
    rpm56 likes this.
  24. krylon32
    krylon32
    from Nebraska
    Super fuse is probably not the right name. I suppose it's called that in my world because of it very large size? Just a farm boy term. Looks like a regular 2 spade fuse on steroids.
    sidevalve8ba, vtx1800 and Roothawg like this.
  25. patsurf
    patsurf
    after all this...and still no pic??
    rpm56 likes this.
  26. alchemy
    alchemy
  27. 19Eddy30
    19Eddy30
    from VA
    o_Oo_O
    There are many type /style shape of
    12v /6v of fuses ,
    I would say he is referring to a
    Large Max / Maxi fuse ,
    or the old looking Shot gun Fuse,
    Strap fuse
    Or large amp circuit breaker
  28. krylon32
    krylon32
    from Nebraska
    I think I found it. Maxi Blade Fuse.
  29. 19Eddy30
    19Eddy30
    from VA
    Ok , Supper Fuse Farm fix!!
    the old screw in gl*** fuse ,
    When it blew ,& your out in the Country the closest store is 30 miles away , it's closed @ 4 pm ,maybe open on Sat, but
    Closed @ noon & closed on Sunday ,so you reached down in your pocket you pulled out a old copper penny stuck it in the hole and screw the fuse back ino_O
    Or old gl*** fuse , blows in winter ,
    Pop fuse out , take & tear off a piece of foil out of your cigarettes ,wrapped it around the fuse and popped it back in..
    Algoma56 likes this.
  30. krylon32
    krylon32
    from Nebraska
    I couldn't agree more!
